I have been trying to figure out why CAS-beacon thread is getting suspended after ~2hrs of running. The application is reading a serial Comport connected to a PC104. The simple driver does use interrupts. When I also include the devIocStats application I did notice that the # CA Clients abruptly went from 3 to some number in excess of 2482020. Running the with or without the devIocStats CAS-beacon eventually get suspended after ~2hrs. EPICS: 3.14.10 IOC: pc104 OS: RTEMS-pc386 w/CEXP SEQ: seq-2.0.12 Can someone give me hints on how to narrow down the source of the problem? Thanks in advance! Sue Witherspoon Accelerator Controls Software Group Thomas Jefferson National Accelerator Facility Here is a snippet of the errors I get after ~2hrs running. CAS: Sending a message of 32 bytes Cexp>rtems_cpu_usage_report()
CPU Usage by thread
ID NAME SECONDS PERCENT
0x09010001 IDLE 7829.680000 99.534
0x0A010001 UI1 4.500000 0.057
0x0A010002 ntwk 0.380000 0.004
0x0A010003 FXPd 0.180000 0.002
0x0A010004 RPCd 0.020000 0.000
0x0A010005 PMAP 0.000000 0.000
0x0A010006 Imsg 0.000000 0.000
0x0A010007 NTPT 0.000000 0.000
0x0A010008 Cloc 0.000000 0.000
0x0A010009 task 0.000000 0.000
0x0A01000A errl 0.020000 0.000
0x0A01000B time 0.000000 0.000
0x0A01000C cbLo 0.000000 0.000
0x0A01000D cbMe 0.000000 0.000
0x0A01000E cbHi 0.000000 0.000
0x0A01000F dbCa 0.000000 0.000
0x0A010010 time 0.000000 0.000
0x0A010011 scan 0.000000 0.000
0x0A010012 scan 0.000000 0.000
0x0A010013 scan 0.000000 0.000
0x0A010014 scan 0.000000 0.000
0x0A010015 scan 0.000000 0.000
0x0A010016 scan 0.000000 0.000
0x0A010017 scan 0.000000 0.000
0x0A010018 scan 0.000000 0.000
0x0A010019 CAS- 0.000000 0.000
0x0A01001B CAS- 0.240000 0.003
0x0A01001C CAS- 0.000000 0.000
0x0A01001D CAS- 0.000000 0.000
0x0A01001E seqA 31.280000 0.397
0x0A01001F bcmt 0.000000 0.000
0x0A010020 CAC- 0.000000 0.000
0x0A010021 CAS- 0.000000 0.000
0x0A010022 CAS- 0.000000 0.000
Time since last CPU Usage reset 7866.300000 seconds
0x00000000 (0)
Cexp>epicsThreadShowAll()
PRIORITY
ID EPICS RTEMS STATE WAIT NAME
0a010001 99 100 RUN _main_
0a010006 99 100 Wmsg 22010004 ImsgDaemon
0a010007 90 109 Wmtx 1a01003f NTPTimeSync
0a010008 90 109 Wmtx 1a010045 ClockTimeSync
0a010009 10 189 RUN taskwd
0a01000a 10 189 Wmtx 1a010054 errlog
0a01000b 70 129 Wmtx 1a010064 timerQueue
0a01000c 59 140 Wmtx 1a010069 cbLow
0a01000d 64 135 Wmtx 1a01006a cbMedium
0a01000e 71 128 Wmtx 1a01006b cbHigh
0a01000f 50 149 Wmtx 1a01006e dbCaLink
0a010010 60 139 Wmtx 1a01007c timerQueue
0a010011 70 129 Wmtx 1a0100ab scanOnce
0a010012 60 139 Wmtx 1a0100ad scan10
0a010013 61 138 Wmtx 1a0100af scan5
0a010014 62 137 Wmtx 1a0100b1 scan2
0a010015 63 136 Wmtx 1a0100b3 scan1
0a010016 64 135 Wmtx 1a0100b5 scan0.5
0a010017 65 134 Wmtx 1a0100b7 scan0.2
0a010018 66 133 Wmtx 1a0100b9 scan0.1
0a010019 18 181 Wevnt CAS-TCP
0a01001a *** RTEMS task gone! *** CAS-beacon
0a01001b 16 183 SUSP CAS-UDP
0a01001c 19 180 Wmtx 1a0100d8 CAS-event
0a01001d 20 179 RUN CAS-client
0a01001e 51 148 RUN seqAux
0a01001f 50 149 RUN bcmtemp_seq
0a010020 51 148 Wmtx 1a0100ee CAC-event
0a010021 19 180 Wmtx 1a0100f8 CAS-event
0a010022 20 179 RUN CAS-client
0x00000000 (0)
Cexp>
| ANJ, 02 Sep 2010 |
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
