g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Subject: Winsock error10004
To: "tech-talk@aps.anl.gov (tech-talk@aps.anl.gov)" <tech-talk@aps.anl.gov>
Date: Fri, 24 Apr 2009 20:54:36 +1000
Hi all,
I'm building a basic IOC under windows XP by doing the following:
makeBaseApp.pl -t ioc <name>
makeBaseApp.pl -i -t ioc <name>
Then I build the ioc, and run it without databases.   The IOC runs without any initialisation errors.  The EPICS version is 3.14.10, and the compiler is Visual C++ Express 2005.  The EPICS build system is set to build statically.
Upon exit I get the following errors
CAS: Client accept error was "WINSOCK Error 10004"
CAS: UDP recv error (errno=WINSOCK Error 10004)
..\online_notify.c: CA beacon routing (connect to "10.123.255.255:5065") error w
as "WINSOCK Error 10093"
or
CA cast server: Unable to fetch N characters pending
Strangely, the ioc's that build under areaDetector 1-4 using win32-x86, do not have this error on exit and run fine.
Has anybody had this error ?  Why is the IOC expecting a response to a broadcast like this ?  Does anyone know how to fix  ?
Thanks heaps,
Mark Clift.
This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
RE: Winsock error10004 Jeff Hill
Prev: Winsock errors Mark Clift
Next: RE: Winsock errors Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Prev: RE: Winsock errors Jeff Hill
Next: RE: Winsock error10004 Jeff Hill
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
