g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Subject: RE: Prosilica cameras and bug in EPICS signal handlers
To: "Jeff Hill" <johill@lanl.gov>, "Andrew Johnson" <anj@aps.anl.gov>, <norume@aps.anl.gov>
Cc: beamline_controls@aps.anl.gov, tech-talk@aps.anl.gov
Date: Thu, 19 Mar 2009 12:16:17 -0500
Jeff and Andrew,
As I mentioned in this March 11 post, I ran into a problem recently
where a vendor's driver library was using the new Posix 1.b timer
routines.  Those routines generate SIGALARM signals, and can cause many
system calls to terminate prematurely with the errno=EINTR.
Andrew and I fixed the Posix implementation of epicsThreadSleep to be
compatible with this.
What I forgot to mention in that earlier post is that the IOC that uses
that vendor's driver produces the following messages from Channel
Access.
CAS: UDP recv error (errno=Interrupted system call)
Is this just a warning message that should be removed, because
interrupted system calls should now be considered "normal"?  Or is it
more serious?
Are there other places in Channel Access or other parts of EPICS where
we need to make changes to correctly handle interrupted system calls?
What about epicsEventWaitWithTimeout(), etc.?
-----Original Message-----
Sent: Wednesday, March 11, 2009 5:25 PM
To: 'John M. Skinner'
Cc: 'Robert Sweet'; 'beamline_controls@aps.anl.gov';
Subject: Prosilica cameras and bug in EPICS signal handlers
Dear John,
I know it's too late for your new camera purchase, but I want to let you
know that I did get the Prosilica cameras working fine with Linux today.
It turns out that it was really a bug in EPICS, not in their driver.
EPICS was installing signal handlers in an obsolete manner that is
incompatible with the new Posix 1.b interval timer library.
With a minor change to the EPICS signal handler functions I can control
Prosilica cameras from Linux with no problem.
EPICS needs additional work to be compatible with the Posix 1.b timer
routines.  These can cause many system calls to terminate prematurely
with the errno=EINTR.  I had to modify the epicsThreadSleep function to
work properly when Posix timers were running, and there will almost
certainly be other places where system calls need to be checked error
returns for this reason.  It's a lot of work, but other developers are
beginning to use these timer functions in their code, and we need to be
able to use code in EPICS.
Cheers,
Prosilica cameras and bug in EPICS signal handlers Mark Rivers
Prev: Re: RTEMS-mvme5500 BSP update Kate Feng
Next: Re: Alarm Limits Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Prev: Prosilica cameras and bug in EPICS signal handlers Mark Rivers
Next: RE: Inter-IOC link problems Shepherd, EL (Emma)
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
