I use MM4000 asynMotor driver to control Newport MM4006 controllers.
The movements are done correctly.
But for certain axis/axes, the DMOV field does not reset to 1 after
position is reached.
I poll the controller status using "MS" command, which reports the axis
is not moving.
Also the MOVN field is going through 0->1->0 sequence correctly.
Other fields when this happens:
MSTA - 0x80a
MIP - 0x420
>From the MIP field, it is waiting for a Delay callback, which never
comes?
To reset DMOV field, I can write 1 to PROC field or any field any can
process
the record but without moving the motor, e.g. SPMG field.
I am using motor 6-2-2 release for asynMotor device support,
but the MM4000 driver is updated to 6-4-2.
Many thanks.
Dr. Xiaoqiang Wang
Paul Scherrer Institut, WBGB/010
5232 Villigen PSI, Switzerland
- RE: MM4000 asynMotor problem Pearson, MR (Matthew)
Re: Looking for feedback on what epics users require Tim Mooney
<2009>
RE: Difficulty with edm installation Kevin Anderson
<2009>
