g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Subject: Re: medm installation
To: tech-talk@aps.anl.gov
Cc: "Mehta, Pratik" <pmehta@bnl.gov>
Date: Wed, 11 Mar 2009 23:16:32 +0100
On Wednesday, 03/11/2009, 17:34 -0400 Mehta, Pratik wrote:
> I am trying to install medm on Ubuntu.
> Installation was successful but I am not able to invoke the application.
> ~/epics/extensions/bin/linux-x86:medm
> bash:medm command not found
> whats wrong?
you don't have the current directory in your $PATH (and rightfully so).
Launch medm using a relative path specification, i.e. ./medm from inside
~/epics/extensions/bin/linux-x86 or an absolute path spec, i.e.
~/epics/extensions/bin/linux-x86/medm from anywhere. In the long run,
you'll probably want to expand your $PATH to contain the extensions bin
directory via
export PATH=$PATH:~/epics/extensions/bin/linux-x86
in your ~/.bashrc or the system-wide equivalent in /etc in order to
launch any EPICS extension from the command line by just typing its
name. While you're at it, do the same for the EPICS base bin directory.
HTH,
-Stefan
Helmholtz-Zentrum Berlin fÃr Materialien und Energie GmbH
Glienicker StraÃe 100, 14109 Berlin
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
Stellvertretende Vorsitzende: Dr. Jutta Koch-Unterseher
GeschÃftsfÃhrer: Prof. Dr. Anke Rita Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Sitz der Gesellschaft: Berlin Handelsregister: AG Charlottenburg, 89 HRB 5583
Information:
Durch die Fusion mit dem ehemaligen Hahn-Meitner-Institut (HMI) ist
BESSY nun Teil des neuen Helmholtz-Zentrum Berlin fÃr Materialien
und Energie (HZB).
By the merger with the former Hahn-Meitner-Institut (HMI), BESSY
became part of the new Helmholtz-Zentrum Berlin fÃr Materialien und
Energie (HZB).
Disclaimer automatically attached by the E-Mail Security Appliance
mail0.bessy.de 03/11/09 at Helmholtz-Zentrum Berlin GmbH.
medm installation Mehta, Pratik
Prev: RE: medm installation Mark Rivers
Next: Prosilica cameras and bug in EPICS signal handlers Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
