g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Subject: makeBaseApp
To: tech-talk@aps.anl.gov
Date: Tue, 10 Mar 2009 15:47:20 +0800
Hi, there's a silly question: how to disable the path conversion
in makeBaseApp?
I'm using EPICS under MinGW+MSYS. The "sh" can recognize
the DOS path, but somehow it fails in "make".
Yes, if I set a path using the DOS version, it just can't find
the executable files. I guess maybe the colon symbol is
used for some "special" case, so anything like C:\epics
will cause unexpected outcomes.
Here's the thing, the makeBaseApp.pl will use UnixPath,
LocalPath, I don't know, to convert the path and write the
base's path to RELEASE, and I always get like
EPICS_BASE=D:\EPICS\base
even I use "-b \epics\base" option. One thing lead to another,
perl could not be found during the make.
So, can I use some magic option to make it?
Best Regards
Chen
          Zhi-chu Chen | Shanghai Synchrotron Radiation Facility
         No. 2019 | Jialuo Rd. | Jiading | Shanghai | P.R. China
             tel: 086 21 5955 3405 | zhichu.chen.googlepages.com
                                               | www.sinap.ac.cn
Re: makeBaseApp Janet Anderson
Prev: Problem with cothread-1-12 on MacOSX (Leopard) Juan Carlos Guzman
Next: RE: Problem with cothread-1-12 on MacOSX (Leopard) Abbott, MG (Michael)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Prev: Re: FW: edm version 1-11-1zl and fedora 10 Brian Bevins
Next: Re: makeBaseApp Janet Anderson
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
