g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Subject: caget with an array of space-containing strings
To: tech-talk@aps.anl.gov
Date: Thu, 26 Feb 2009 13:57:56 -0600
I am using the command-line caget with an array of space-containing strings. Apparently caget uses spaces to separate array elements. A space separator causes some difficultly in this case because the elements themselves contains spaces. For example, ...
clx39:~ $ caget -# 1 ADC00.RNGS
ADC00.RNGS 50, 10k: -10->0
clx39:~ $ caget ADC00.RNGS
ADC00.RNGS 9 50, 10k: -10->0 50, 10k: +-5 50, 10k: 0->10 50: -6->0, 10k: -5->0 50: +-3, 10k: +-2.5 50, 10k: 0->5 50: -5->0, 10k: -2->0 50: +-2.5, 10k: +-1 50: 0->5, 10k: 0->2
clx39:~ $
One can ask for specific elements as I have done, but that is a little bit inconvenient. Any suggestions?
Carl Schumann
Re: caget with an array of space-containing strings J. Lewis Muir
Re: caget with an array of space-containing strings Andrew Johnson
Re: caget with an array of space-containing strings Matthieu Bec
Re: caget with an array of space-containing strings Dirk Zimoch
Prev: Re: AW: Snl strings Eric Norum
Next: Re: caget with an array of space-containing strings J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Prev: vme usb support David Kline
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
