g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Subject: Re: Asyn driver access to PV fields.
To: tieman <tieman@aps.anl.gov>
Cc: tech talk <tech-talk@aps.anl.gov>
Date: Fri, 20 Feb 2009 09:42:54 +0100
Hi Brian,
StreamDevice can do this. Use a combination of @init handler and "%(ZRST)16c" redirection. See http://epics.web.psi.ch/software/streamdevice/doc/ chapters "Record Processing" -> "Initialization" and "Format Converters" -> "Types & Fields".
It might be possible that not all client applications get the enums correctly. If the client is already connected and you reboot the ioc and it starts up with new enum strings, the client might still use the old enums.
Dirk
tieman wrote:
Hi all!
I have a situation where I have an mbbo field that I would like to set programmatically at run time. Specifically, I would like to set ZSTR, ONST, etc... to specific values that are read back from hardware in a device driver at initialization. How can I do this from within an Asyn driver?
Thanks!
Brian
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
Asyn driver access to PV fields. tieman
Prev: Re: Asyn driver access to PV fields. Marty Kraimer
Next: RE: Asyn driver access to PV fields. Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Prev: Re: Asyn driver access to PV fields. tieman
Next: Mac OS X and environ Stephen Norum
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
