g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Subject: Re: wrong timestamps in monitors
To: Andrew Johnson <anj@aps.anl.gov>
Cc: EPICS tech-talk <tech-talk@aps.anl.gov>
Date: Fri, 30 Jan 2009 09:30:05 +0100
Andrew Johnson wrote: ...
I believe it is well-recognized that the status and severity of a PV reflect the state of the record containing that PV rather than the state of PV value itself.
This is not fully true.
* The "pseudo fields" RTYP and VERS report random (?) status and severity.
* When using monitors on fields, lets say EGU, status and severity are not updated when they change and thus do not reflect the state of the PV.
BTW: Many records have a general problem reporting correct attributes to any field but VAL. For example, reporting the EGU field as the units of the PREC field is obvious nonsense.
Dirk
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
Re: wrong timestamps in monitors Andrew Johnson
wrong timestamps in monitors Benjamin Franksen
Prev: EDM text control for password entry Steve Kinder
Next: Re: wrong timestamps in monitors Goetz Pfeiffer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Prev: Re: wrong timestamps in monitors Andrew Johnson
Next: Re: wrong timestamps in monitors Andrew Johnson
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
