g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013
Subject: RE: epics dbpf problem
To: "Williams Jr., Ernest L." <ernesto@slac.stanford.edu>, <tech-talk@aps.anl.gov>
Date: Wed, 15 Oct 2008 20:10:45 +0800
Dear Ernest
     first thank you for your answer.
     the database record R4IBT04:CISet is like this
record(ao,"R4IBT04:CISet") {
field(DESC, "analog output record")
field(SCAN, "Passive")
field(OUT, “#C1 S0 @SPT”)
field(PINI, "NO")
field(PHAS, "0")
field(EVNT, "0")
field(DTYP, "PSC")
field(DISV, "1")
field(SDIS, "0.000000000000000e+00")
field(DISS, "NO_ALARM")
field(PRIO, "LOW")
field(FLNK, "0.000000000000000e+00")
field(OROC, "0.0000000e+00")
field(DOL, "0.000000000000000e+00")
field(OMSL, "supervisory")
field(OIF, "Full")
field(PREC, "3")
field(LINR, "NO CONVERSION")
field(EGUF, "0.0000000e+00")
field(EGUL, "0.0000000e+00")
field(EGU, "amps")
field(ESLO, "0.0000000e+00")
field(EOFF, "0.0000000e+00")
field(ASLO, "1.50000000e-04")
field(AOFF, "-5.1000000e+00")
field(DRVH, "0.0000000e+00")
field(DRVL, "0.0000000e+00")
field(HOPR, "4.500000e+00")
field(LOPR, "-4.5000000e+00")
field(HIHI, "5.0000000e+00")
field(LOLO, "-5.0000000e+00")
field(HIGH, "0.0000000e+00")
field(LOW, "0.0000000e+00")
field(HHSV, "NO_ALARM")
field(LLSV, "NO_ALARM")
field(HSV, "NO_ALARM")
field(LSV, "NO_ALARM")
field(HYST, "0.000000000000000e+00")
field(ADEL, "0.000000000000000e+00")
field(MDEL, "0.000000000000000e+00")
field(SIOL, "0.000000000000000e+00")
field(SIML, "0.000000000000000e+00")
field(SIMS, "NO_ALARM")
field(IVOA, "Continue normally")
field(IVOV, "0.000000000000000e+00")}
I don't know what RTYP refers to. but after I try it like this
Cexp> dbl("","RTYP")
RTYP could not be created
0x00000000(0)
I wonder whether it's DTYP
but even it DTYP , it gives the same result
anywhere is wrong? any help is appreciated, thanks!!
Haoli
Oct 15, 2008
On Tue, 14 Oct 2008 22:41:51 -0700, Williams Jr., Ernest L. wrote
> Hi,
> You syntax looks okay:
> What is your record type for R4IBT04:CISet?
> Cexp>dbl("", "RTYP")
> Thanks,
> Ernest
> ________________________________
> From: tech-talk-bounces@aps.anl.gov on behalf of Shi HaoLi
> Sent: Tue 10/14/2008 7:24 PM
> To: tech-talk@aps.anl.gov
> Subject: epics dbpf problem
> Hi, all
>    Now I've built an EPICS (version 3.14.6) application using
> RTEMS(4.6.0), IOC is MVME5500. The peripheral hardware I/O module is
> PSC. The device support(devPSC.c) and the driver support(drvPSC.c)
> have been successfully compiled and can run on RTEMS. Database
> downloading related to PSC is OK, but when I execute dbpf, something
> wrong happens as follows:
> Cexp>dbpf ("R4IBT04:CISet", "3.0")
> 0xffffffff (-1)
> filename="../dbTest.c" line number=365
> dbPutField error
> Cexp>dbgf ("R4IBT04:CISet")
> DBR_DOUBLE          3
> Cexp>dbl()
> R4IBT04:CISet
> R4IBT04:I
> R4IBT04:ISet
> any help is appreciated, thanks a lot!
> Haoli Shi
Open WebMail Project (http://openwebmail.org)
Re: epics dbpf problem Thomas Birke
epics dbpf problem Shi HaoLi
RE: epics dbpf problem Williams Jr., Ernest L.
Prev: CA client application M.Babai
Next: Re: epics dbpf problem Thomas Birke
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013
Prev: RE: epics dbpf problem Williams Jr., Ernest L.
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
