g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013
Subject: Are EDM screens forwards compatible from version 1-10 to 1-11?
From: Mark Bennett <mark.bennett@synchrotron.vic.gov.au>
To: EPICS tech-talk <tech-talk@aps.anl.gov>
Date: Wed, 27 Feb 2008 10:57:26 +1100
We have a number of EDM screens that were developed using EDM version 1-10-1w. As this version does not compile under CentOS 5.0, I thought I would try the latest version of EDM (1-11-1 at the time of writing). This latter version compiles with no problems once the correct dependencies are installed (openmotif, giflib).
However, the EDM screens will not run under this new version.
Are 1-10 edl files forwards compatible with 1-11?
If yes, any suggestions on what I might be doing wrong?
If no, is there a conversion tool?
Mark Bennett
Principal Controls Engineer
Australian Synchrotron
Re: Are EDM screens forwards compatible from version 1-10 to 1-11? John Sinclair
Prev: SLC500 John Faucett
Next: Re: Problem with soft motor record Shepherd, EL (Emma)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013
Next: Re: Are EDM screens forwards compatible from version 1-10 to 1-11? John Sinclair
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
