I have a soft IOC which I evolved from myExample template. It uses a suport module which is built from asyn devGpib template. Initially, the only device IO done in the application was via asynRecords, all other records were of "Soft Channel" or <nil> type. The application worked fine.
Today I added the following record:
record( stringin, "$(P)IDN"){
field( DESC, "To keep the connection alive")
# field( DTYP, "ks3988")
# field( SCAN, "5 second")
# field( INP, "#L$(L) A0, @0")
To the devxxxx.db file and
device( stringin, GPIB_IO, devSiKS3988, "ks3988")
To the devxxxx.dbd file and
#define DSET_SI devSiKS3988
static char sform[]="%39[^\r\n]";
static struct gpibCmd gpibCmds[]={
{&DSET_SI,GPIBREAD,IB_Q_LOW,"*IDN?",sform,0,128,NULL,0,0,NULL,NULL,NULL},
To the devxxxx.c file. The module compiles ok and the application compiles and links ok too. With the line field( DTYP, "ks3988") commented out the application does not crash. As soon as I uncomment the line and remake everything, the application crashes with Segmentation fault. Here is what I see with gdb:
#!../../bin/linux-x86/ksTest
< envPaths
epicsEnvSet(ARCH,"linux-x86")
epicsEnvSet(IOC,"iocksTest")
epicsEnvSet(TOP,"/afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/ksTest")
epicsEnvSet(ASYN,"/afs/slac/g/esa/ilc/epics/modules/asyn/4-8")
epicsEnvSet(GENSUB,"/afs/slac/g/esa/ilc/epics/modules/genSub/1-6")
epicsEnvSet(KS3988,"/afs/slac/g/esa/ilc/epics/modules/ks3988")
epicsEnvSet(EPICS_BASE,"/afs/slac/g/esa/ilc/epics/base/R3-14-9-ilc1")
cd /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/ksTest
dbLoadDatabase("dbd/ksTest.dbd")
ksTest_registerRecordDeviceDriver(pdbbase)
vxi11Configure( "L0","134.79.64.25",0,0.0,"gpib0",0,0)
## Load record instances
dbLoadRecords( "db/dbExample1.db","P=KS:")
dbLoadRecords( "db/devKS3988.db","P=KS:,Q=AIO,W=AWRT,L=0,A=12")
dbLoadRecords( "db/asynIO.db","P=KS:,R=AIO,PORT=L0,ADDR=12,IMAX=100,OMAX=100")
dbLoadRecords( "db/asynWrt.db","P=KS:,R=AWRT,PORT=L0,ADDR=12,IMAX=100,OMAX=100")
cd /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/ksTest/iocBoot/iocksTest
iocInit()
Starting iocInit
## EPICS R3.14.9-lcls1 $R3-14-9$ $2007/02/05 16:31:45$
## EPICS Base built Oct 2 2007
Segmentation fault (core dumped)
zms@esaux1 $ gdb ../../bin/linux-x86/ksTest core.14360
GNU gdb Red Hat Linux (6.3.0.0-1.143.el4rh)
Copyright 2004 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "i386-redhat-linux-gnu"...Using host libthread_db lib
rary "/lib/tls/libthread_db.so.1".
Core was generated by `../../bin/linux-x86/ksTest st.cmd'.
Program terminated with signal 11, Segmentation fault.
Reading symbols from /afs/slac.stanford.edu/g/esa/ilc/epics/modules/ks3988/lib/l
inux-x86/libdevKS3988.so...done.
.... Omitted many lines here
#0 0x003cb393 in initRecord (precord=0x9759168, plink=0x97592e4)
at ../../asyn/devGpib/devSupportGpib.c:230
230 if (pgpibCmd->dset != (gDset *) precord->dset) {
(gdb) bt
#1 0x003c98f6 in devGpib_initSi (psi=0x9759168)
at ../../asyn/devGpib/devCommonGpib.c:941
#2 0x0073f488 in init_record (pstringin=0x9759168, pass=1)
at ../stringinRecord.c:122
#3 0x0051c717 in iocInit () at ../iocInit.c:352
#4 0x009875be in iocInitCallFunc (args=0x96fa158) at ../dbAccessRegister.c:69
#5 0x009895d1 in iocshBody (pathname=0xbff715b9 "st.cmd", commandLine=0x0)
at ../iocsh.cpp:743
#6 0x0804af62 in main (argc=2, argv=0x698ad30) at ../ksTestMain.cpp:17
Current language: auto; currently c
(gdb)
I am working with EPICS R3.14.9 and asyn 4-8.
Any idea what I am doing wrong?
Thanks in advance,
Zen
Re: fedora core 7 medm (was >> Re: MEDM compile - update :) Noboru Yamamoto
Re: Display array of number in edm John Sinclair
<2007>
Visibility settings in EDM Dave Reid
<2007>
