I am not familiar with the VXI-11 controller you are using. But I do
know that many Modbus TCP controllers will close the connection after a
few seconds of inactivity. Perhaps your VXI-11 controller is doing the
same thing. Can you try putting an EPICS record that is periodically
scanned and reads some value from the controller to see if this keeps
the socket connection alive?
> -----Original Message-----
> From: tech-talk-bounces@aps.anl.gov
> [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of Szalata, Zenon M.
> Sent: Tuesday, October 16, 2007 12:47 PM
> To: EPICS tech-talk
> Subject: asyn
> My soft IOC program generates errors, see below. I control
> the IOC from an edm panel, where one of the controlls tells
> the IOC to write a sring of bytes to the gpib KS3988 crate
> controller and then read the response. When I press the
> button soon after the IOC is started it seems to be working
> fine. However if I wait a few minutes after the IOC is
> started and then press the button the program generates
> errors. Sometimes it crashes with seg fault, like it did
> this time, and sometimes it recoveres after two subsequent
> button clicks. Looks like the connection to the device times
> out. Any ideas how to fix it?
> Here is the output:
> zms@esaux1 $ ../../bin/linux-x86/ksTest st.cmd
> #!../../bin/linux-x86/ksTest
> < envPaths
> epicsEnvSet(ARCH,"linux-x86")
> epicsEnvSet(IOC,"iocksTest")
> epicsEnvSet(TOP,"/afs/slac.stanford.edu/g/esa/ilc/epics/iocTop
> /ksTest")
> epicsEnvSet(ASYN,"/afs/slac/g/esa/ilc/epics/modules/asyn/4-8")
> epicsEnvSet(GENSUB,"/afs/slac/g/esa/ilc/epics/modules/genSub/1-6")
> epicsEnvSet(KS3988,"/afs/slac/g/esa/ilc/epics/modules/ks3988")
> epicsEnvSet(EPICS_BASE,"/afs/slac/g/esa/ilc/epics/base/R3-14-9-ilc1")
> cd /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/ksTest
> ## Register all support components
> dbLoadDatabase("dbd/ksTest.dbd")
> ksTest_registerRecordDeviceDriver(pdbbase)
> vxi11Configure( "L0","134.79.64.25",0,0.0,"gpib0",0,0)
> ## Load record instances
> dbLoadRecords( "db/dbExample1.db","P=KS:")
> dbLoadRecords( "db/devKS3988.db","P=KS:,Q=AIO,W=AWRT,L=0,A=12")
> dbLoadRecords(
> "db/asynIO.db","P=KS:,R=AIO,PORT=L0,ADDR=12,IMAX=100,OMAX=100")
> dbLoadRecords(
> "db/asynWrt.db","P=KS:,R=AWRT,PORT=L0,ADDR=12,IMAX=100,OMAX=100")
> cd
> /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/ksTest/iocBoot/iocksTest
> iocInit()
> Starting iocInit
> ## EPICS R3.14.9-lcls1 $R3-14-9$ $2007/02/05 16:31:45$
> ## EPICS Base built Oct 2 2007
> iocInit: All initialization complete
> epics> ksReadReg: c=12, n=0, a=0, f=1, nw=1, d=0, l=0, sm=0, dm=0
> ksReadReg 3 bytes: 0x1e 0x0 0x1
> This is a message number 0
> 2007/10/16 10:34:42.245 L0 vxi11 clientIoCall errno 104 clnt_stat 4
> 2007/10/16 10:34:42.245 L0 vxiDestroyDevLink RPC error : RPC:
> Unable to send; er
> rno = Broken pipe
> 2007/10/16 10:34:42.246 L0 vxiDisconnectPort : RPC: Unable to
> send; errno = Brok
> en pipe
> 2007/10/16 10:34:44.247 L0 vxiDestroyDevLink RPC error : RPC:
> Unable to send; er
> rno = Broken pipe
> L0 port not connected
> 2007/10/16 10:34:44.247 L0 asynGpib:pollAddr srqEnable
> 2007/10/16 10:34:44.247 KS:AIO: Write error, nout=0, L0 RPC failed
> 2007/10/16 10:34:44.247 L0 port not connected
> 2007/10/16 10:34:44.247 KS:AIO: Error L0 port is not connected
> 2007/10/16 10:34:44.247 KS:AIO: error nread -1210113632 L0
> d
> 2007/10/16 10:34:44.247 KS:AIO: Overflow nread -1210113632 L0
> port is not connec
> ted
> Segmentation fault (core dumped)
> Thanks,
> Zen
- asyn Szalata, Zenon M.
Re: Installing EDM on OS X 10.4.10 Bertrand H.J. Biritz
<2007>
Display array of number in edm Szalata, Zenon M.
<2007>
