I am working on the port of EPICS to ETRAX CRIS architecture running Linux. We are using several boards which either have Axis's chips: ETRAX LX100 MCM (cris_v10) (http://www.axis.com/techsup/dev/etrax_100lx_mcm/index.htm) or ETRAX FS (cris_v32) (http://www.axis.com/techsup/dev/etrax_100lx_mcm/index.htm) as a control unit on-board. I meanwhile have succeeded ( :-) ) in compiling EPICS 3.14.9 on a linux-x86 host-system for those two architectures: - The CONFIG files needed to be create are documented at: linux-cris_10: http://wiki.gsi.de/Epics/ConfigurationEpicsCrossCompileLinuxCrisV10 linux-cris_32: http://wiki.gsi.de/Epics/ConfigurationEpicsCrossCompileLinuxCrisV32 where exclusively linux-cris files have been modified/created. - Changes in CONFIG_SITE.linux-x86.Common:
CROSS_COMPILER_TARGET_ARCHS = linux-cris_v10 linux-cris_v32- The cross-compiler used is a gnu-compiler provided by axis: cris-gcc --version: cris-axis-elf-gcc (GCC) 3.2.1 Axis release R64/1.64 - The file "$EPICS-BASE/src/libCom/osi/default/osdWireFormat.h" has been extended by those two lines to comply for the little-endianness : #elif defined (_cris_) # define EPICS_LITTLE_ENDIAN - The optimization -O3 had to be replaced by -Os or the default -O0 to be able to compile. Also the example Application created via |$EPICS_BASE/bin/linux-x86/makeBaseApp.pl |compiles ||meanwhile without problems. Copied to the target system (cris_v10 Target) the IOC starts up thoroughly. "dbl, dbpr, etc" applied to all given records seem to work. But, pardon me for the long introduction, (either locally or remotely) looking with a client application to the the values the data are corrupted: using *camonitor* gives for aiExample2 (normally having a counter running from 0 to 9): zumbruchHost:aiExample2 2007-08-22 20:08:32.843735 4.33197e-320 ?? ?? zumbruchHost:aiExample2 2007-08-22 20:08:34.853797 0 ?? ?? zumbruchHost:aiExample2 2007-08-22 20:08:36.864724 3.03865e-319 ?? ?? zumbruchHost:aiExample2 2007-08-22 20:08:38.873781 3.16202e-322 ?? ?? zumbruchHost:aiExample2 2007-08-22 20:08:40.883986 1.04347e-320 ?? ?? zumbruchHost:aiExample2 2007-08-22 20:08:42.894597 2.05531e-320 ?? ?? zumbruchHost:aiExample2 2007-08-22 20:08:44.903989 2.56124e-320 zumbruchHost:aiExample2 1904-10-15 19:11:38.551617 3.06716e-320 ?? ?? zumbruchHost:aiExample2 2007-08-22 20:08:48.924495 3.57308e-320 ?? ?? zumbruchHost:aiExample2 2007-08-22 20:08:50.933987 4.07901e-320 ?? ?? zumbruchHost:aiExample2 2007-08-22 20:08:52.944423 4.33197e-320 ?? ?? zumbruchHost:aiExample2 1909-01-16 05:53:46.278750 0 ?? ?? zumbruchHost:aiExample2 1910-02-08 14:34:18.543753 3.03865e-319 ?? ?? zumbruchHost:aiExample2 1911-03-03 23:14:50.955094 3.16202e-322 ?? ?? zumbruchHost:aiExample2 2007-08-22 20:09:00.984164 1.04347e-320 ?? ?? zumbruchHost:aiExample2 1913-04-18 16:35:54.407488 2.05531e-320 ?? ?? zumbruchHost:aiExample2 1914-05-12 01:16:26.675635 2.56124e-320 zumbruchHost:aiExample2 2007-08-22 20:09:07.014232 3.06716e-320 ?? ?? zumbruchHost:aiExample2 2007-08-22 20:09:09.024221 3.57308e-320 ?? ?? zumbruchHost:aiExample2 2007-08-22 20:09:11.034747 4.07901e-320 ?? ?? zumbruchHost:aiExample2 2007-08-22 20:09:13.044186 4.33197e-320 ?? ?? zumbruchHost:aiExample2 1919-09-04 20:39:06.413164 0 ?? ?? for comparison a similar well running application ("What it should look like") zumbruch2Host:aiExample2 2007-08-22 20:08:32.613470 1 LOLO MAJOR zumbruch2Host:aiExample2 2007-08-22 20:08:34.615208 2 LOLO MAJOR zumbruch2Host:aiExample2 2007-08-22 20:08:36.617301 3 LOW MINOR zumbruch2Host:aiExample2 2007-08-22 20:08:38.618697 4 LOW MINOR zumbruch2Host:aiExample2 2007-08-22 20:08:40.620584 5 zumbruch2Host:aiExample2 2007-08-22 20:08:42.622103 6 HIGH MINOR zumbruch2Host:aiExample2 2007-08-22 20:08:44.623496 7 HIGH MINOR zumbruch2Host:aiExample2 2007-08-22 20:08:46.624957 8 HIHI MAJOR zumbruch2Host:aiExample2 2007-08-22 20:08:48.627479 9 HIHI MAJOR zumbruch2Host:aiExample2 2007-08-22 20:08:50.629924 0 LOLO MAJOR zumbruch2Host:aiExample2 2007-08-22 20:08:52.631170 1 LOLO MAJOR The same for *ca_test*: name: zumbruchHost:aiExample2 native type: DBR_DOUBLE native count: 1 DBR_STRING 3 DBR_SHORT 768 DBR_FLOAT 0.0000 DBR_ENUM 768 DBR_CHAR 3 DBR_LONG 50331648 DBR_DOUBLE 0.0000 DBR_STS_STRING 1536 256 Value: 3 DBR_STS_SHORT 1536 256 Value: 768 DBR_STS_FLOAT 1536 256 Value: 0.0000 DBR_STS_ENUM 1536 256 Value: 768 DBR_STS_CHAR 1536 256 Value: 3 DBR_STS_LONG 1536 256 Value: 50331648 DBR_STS_DOUBLE 1536 256 Value: 0.0000 DBR_TIME_STRING 1536 256 TimeStamp: 1901/12/13 21:45:52.547135 Value: 3 DBR_TIME_SHORT 1536 256 TimeStamp: 1901/12/13 21:45:52.547135 Value: 768 DBR_TIME_FLOAT 1536 256 TimeStamp: 1901/12/13 21:45:52.547135 Value: 0.0000 DBR_TIME_ENUM 1536 256 TimeStamp: 1901/12/13 21:45:52.547135 Value: 768 DBR_TIME_CHAR 1536 256 TimeStamp: 1901/12/13 21:45:52.547135 Value: 3 DBR_TIME_LONG 1536 256 TimeStamp: 1901/12/13 21:45:52.547135 Value: 50331648 DBR_TIME_DOUBLE 1536 256 TimeStamp: 1901/12/13 21:45:52.547135 Value: 0.0000 DBR_GR_STRING 1536 256 Value: 3 DBR_GR_SHORT 1536 256 Counts 2560 0 2048 1536 1024 512 Value: 768 DBR_GR_FLOAT 1536 256 Counts 0 0.000 0.000 0.000 0.000 0.000 0.000 Value: 0.0000 DBR_GR_ENUM 1536 256 Value: 768 DBR_GR_CHAR 1536 256 Counts 10 0 8 6 4 2 Value: 3 DBR_GR_LONG 1536 256 Counts 167772160 0 134217728 100663296 67108864 33554432 Value: 50331648 DBR_GR_DOUBLE 1536 256 Counts 0 0.000 0.000 0.000 0.000 0.000 0.000 Value: 0.0000 DBR_CTRL_STRING 1536 256 Value: 3 DBR_CTRL_SHORT 1536 256 Counts 2560 0 2048 1536 1024 512 2560 0 Value: 768 DBR_CTRL_FLOAT 1536 256 Counts 0 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 Value: 0.0000 DBR_CTRL_ENUM 1536 256 Value: 768 DBR_CTRL_CHAR 1536 256 Counts 10 0 8 6 4 2 10 0 Value: 3 DBR_CTRL_LONG 1536 256 Counts 167772160 0 134217728 100663296 67108864 33554432 167772160 0 Value: 50331648 DBR_CTRL_DOUBLE 1536 256 Counts 0 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 Value: 0.000000 DBR_STSACK_STRING 1536 256 256 512 3 DBR_CLASS_NAME ai and what it should look like: name: zumbruch2Host:aiExample2 native type: DBR_DOUBLE native count: 1 DBR_STRING 3 DBR_SHORT 3 DBR_FLOAT 3.0000 DBR_ENUM 3 DBR_CHAR 3 DBR_LONG 3 DBR_DOUBLE 3.0000 DBR_STS_STRING 6 1 Value: 3 DBR_STS_SHORT 6 1 Value: 3 DBR_STS_FLOAT 6 1 Value: 3.0000 DBR_STS_ENUM 6 1 Value: 3 DBR_STS_CHAR 6 1 Value: 3 DBR_STS_LONG 6 1 Value: 3 DBR_STS_DOUBLE 6 1 Value: 3.0000 DBR_TIME_STRING 6 1 TimeStamp: 2007/08/22 20:15:16.962527 Value: 3 DBR_TIME_SHORT 6 1 TimeStamp: 2007/08/22 20:15:16.962527 Value: 3 DBR_TIME_FLOAT 6 1 TimeStamp: 2007/08/22 20:15:16.962527 Value: 3.0000 DBR_TIME_ENUM 6 1 TimeStamp: 2007/08/22 20:15:16.962527 Value: 3 DBR_TIME_CHAR 6 1 TimeStamp: 2007/08/22 20:15:16.962527 Value: 3 DBR_TIME_LONG 6 1 TimeStamp: 2007/08/22 20:15:16.962527 Value: 3 DBR_TIME_DOUBLE 6 1 TimeStamp: 2007/08/22 20:15:16.962527 Value: 3.0000 DBR_GR_STRING 6 1 Value: 3 DBR_GR_SHORT 6 1 Counts 10 0 8 6 4 2 Value: 3 DBR_GR_FLOAT 6 1 Counts 0 10.000 0.000 8.000 6.000 4.000 2.000 Value: 3.0000 DBR_GR_ENUM 6 1 Value: 3 DBR_GR_CHAR 6 1 Counts 10 0 8 6 4 2 Value: 3 DBR_GR_LONG 6 1 Counts 10 0 8 6 4 2 Value: 3 DBR_GR_DOUBLE 6 1 Counts 0 10.000 0.000 8.000 6.000 4.000 2.000 Value: 3.0000 DBR_CTRL_STRING 6 1 Value: 3 DBR_CTRL_SHORT 6 1 Counts 10 0 8 6 4 2 10 0 Value: 3 DBR_CTRL_FLOAT 6 1 Counts 0 10.000 0.000 8.000 6.000 4.000 2.000 10.000 0.000 Value: 3.0000 DBR_CTRL_ENUM 6 1 Value: 3 DBR_CTRL_CHAR 6 1 Counts 10 0 8 6 4 2 10 0 Value: 3 DBR_CTRL_LONG 6 1 Counts 10 0 8 6 4 2 10 0 Value: 3 DBR_CTRL_DOUBLE 6 1 Counts 0 10.000 0.000 8.000 6.000 4.000 2.000 10.000 0.000 Value: 3.000000 DBR_STSACK_STRING 6 1 1 2 3 DBR_CLASS_NAME ai Could somebody give me an advice where else to look at? Thanks in advance, Peter -- Dr. Peter W. Zumbruch EE - department / Controls group / GSI E-Mail: P.Zumbruch@gsi.de Tel: +49-(6159)-71-1435 / Fax: +49-(6159)-71-2986 Gesellschaft für Schwerionenforschung mbH Planckstraße 1 / D-64291 Darmstadt / www.gsi.de Gesellschaft mit beschränkter Haftung Sitz der Gesellschaft: Darmstadt Handelsregister: Amtsgericht Darmstadt, HRB 1528 Geschäftsführer: Professor Dr. Horst Stöcker, Dr. Alexander Kurz Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph, Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
| ANJ, 10 Nov 2011 |
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
