g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013
Subject: breakpoint table bug R3.14.8
To: tech_talk <tech-talk@aps.anl.gov>
Date: Wed, 15 Aug 2007 13:43:02 -0700
The breakpoint table bug, which I reported last year (see tech-talk thread starting: Fri, 12 May 2006) is back in R3.14.8.2. Maybe it was never fixed? We are still running mostly R3.13.10, where I had implemented my own fix locally. Now we installed a Linux based IOC and our Silicon Diode breakpoint conversions screw up again.
(Just to save you looking up the thread: If you have a table, where the raw values are increasing and the engineering values are decreasing, the algorithm as implemented doesn't work correctly).
- rolf -
| Rolf Keitel, Ph.D., TRIUMF        Tel: (604) 222-7453 |
| Manager Electronics and Controls  Fax: (604) 222-7307 |
| Engineering Division                                  |
| Vancouver, B.C., Canada                               |
Re: breakpoint table bug R3.14.8 Andrew Johnson
Prev: Re: SDDS? Andrew Johnson
Next: Re: breakpoint table bug R3.14.8 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
