g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013
Subject: Re: Scan question
From: Emmanuel Mayssat <emmanuel_mayssat@lynceantech.com>
To: Heinrich du Toit <heinrichdt@tlabs.ac.za>
Cc: TechTalk EPICS <tech-talk@aps.anl.gov>
Date: Thu, 12 Jul 2007 10:15:50 -0700
Why don't you try? ;-)
I never tried changing it inside a record, but frequently do it through
database processing or the m/edm GUI. (I do this mostly for debugging
purpose)
Of course when you change it, you need to do it according to the/your
menuScan.dbd file.
Also you can do with dbLoadRecord if it is only a 1 time setting.
On Thu, 2007-07-12 at 16:05 +0200, Heinrich du Toit wrote:
> Can I change the SCAN field at runtime?
> E.g. inside my own custom record.
> Some devices normally needs only be scanned say once a sec or every 5
> secs. But then when you change the value you want the scanned faster at
> say 0.2 secs.
Re: Scan question John Faucett
Scan question Heinrich du Toit
Prev: Re: dbLoadRecord or dbLoadTemplate Andrew Johnson
Next: RE: Scan question Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013
Prev: Scan question Heinrich du Toit
Next: Re: Scan question John Faucett
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
