Hi Heinrich
You must load EVERYTHING before iocInit().
Dirk
Heinrich du Toit wrote:
figured it out!!
The order of command in my st.cmd was wrong.
For some reason I must load asynRecord:
dbLoadRecords("../../db/asynRecord.db","P=asyn,R=A,PORT=port0,ADDR=6,IMAX=0,OMAX=0")
before I call iocInit()
else the lockSets aren't setup correctly.
I don't really understand why this is so?
sorry for the trouble :)
There is just so much about epics I am yet to understand
-Heinrich
On Tue, 2007-06-19 at 12:44 +0200, Heinrich du Toit wrote:
Hi
I've started experimenting with asyn.
Now I've created the routines for a driver with Common and devInt32
interfaces.
When I connected my own record (ai) 2 this to read it works fine.
Then I tried connecting a asynRecord to this.
It starts up fine.
But when I run medm to see this record the IOC segfaults.
plockRecord->plockSet
because plockSet = null
and this is because precord->lst = null
And that must be the lockRecord or something.
I don't understand, the stack trace doesn't even run through asyn or my
own code.
I have no idea where to look for the fault :(
-Heinrich
Dr. Dirk Zimoch
Computing and Controls
Paul Scherrer Institut
phone +41 56 310 5182
fax +41 56 310 4413
- asynRecord SEGFAULT? Heinrich du Toit
- Re: asynRecord SEGFAULT? Heinrich du Toit
another asyn question... Heinrich du Toit
<2007>
<2007>
