g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013
Subject: Re: asynRecord SEGFAULT?
To: TechTalk EPICS <tech-talk@aps.anl.gov>
Date: Tue, 19 Jun 2007 15:35:37 +0200
figured it out!!
The order of command in my st.cmd was wrong.
For some reason I must load asynRecord:
dbLoadRecords("../../db/asynRecord.db","P=asyn,R=A,PORT=port0,ADDR=6,IMAX=0,OMAX=0")
before I call iocInit()
else the lockSets aren't setup correctly.
I don't really understand why this is so?
sorry for the trouble :)
There is just so much about epics I am yet to understand
-Heinrich
On Tue, 2007-06-19 at 12:44 +0200, Heinrich du Toit wrote:
> Hi
> I've started experimenting with asyn.
> Now I've created the routines for a driver with Common and devInt32
> interfaces.
> When I connected my own record (ai) 2 this to read it works fine.
> Then I tried connecting a asynRecord to this.
> It starts up fine.
> But when I run medm to see this record the IOC segfaults.
> location: base/src/db/dbLock.c line 242 : plockSet =
> plockRecord->plockSet
> because plockSet = null
> and this is because precord->lst = null
> And that must be the lockRecord or something.
> I don't understand, the stack trace doesn't even run through asyn or my
> own code.
> I have no idea where to look for the fault :(
> -Heinrich
Re: asynRecord SEGFAULT? Dirk Zimoch
asynRecord SEGFAULT? Heinrich du Toit
Prev: RE: asynRecord SEGFAULT? Mark Rivers
Next: Re: asynRecord SEGFAULT? Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
