g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013
Subject: VXI11 ASYN problem on VxWorks
From: Matthew Pearson <matthew.pearson@diamond.ac.uk>
To: tech-talk talk <tech-talk@aps.anl.gov>
Date: Fri, 15 Jun 2007 16:29:30 +0100
I'm trying to use a GPIB device via the VXI11 Agilent E5810A, by using the ASYN support for the E5810A. So in my IOC start up file I have:
iocshCmd("vxi11Configure L0 172.23.116.185 0 0.0 gpib0 0 0")
but at start up I get:
2007/06/15 15:17:53.852 L0 vxiConnectPort error 172.23.116.185: RPC: Program not registered
2007/06/15 15:17:53.852 asynManager::asynConnectCallback, port L0 error calling asynCommon->connect
2007/06/15 15:17:53.852  L0 -1 autoConnect could not connect
2007/06/15 15:17:53.885 L0 vxiConnectPort error 172.23.116.185: RPC: Program not registered
2007/06/15 15:17:53.968 asynManager::asynConnectCallback, port L0 error calling asynCommon->connect
2007/06/15 15:17:54.868 L0 port not connected
2007/06/15 15:17:58.618 L0 vxi11 clientCall errno 3997698 clnt_stat 0
2007/06/15 15:17:58.618 L0 vxiConnectPort vxiBusStatus error initialization aborted
0x1ea12bc0 (L0): memPartFree: invalid block 0x1e247e80 in partition 0x265d1c.
Have people seen something like this before? I'm not sure if the E5810A is widely used or not.
The device itself is fine. The above works OK if I am using a linux IOC. Also, the VxWorks IOC can see the E5810A because it send a reboot command successfully.
Cheers,
Matthew
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0D! E, United Kingdom
Re: VXI11 ASYN problem on VxWorks Eric Norum
Prev: Re: IOC options David Kline
Next: Re: VXI11 ASYN problem on VxWorks Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013
Prev: RE: protocol/database macro expansion problem Pearson, MR (Matthew)
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
