g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013
Subject: Re: IOC options
To: tech-talk talk <tech-talk@aps.anl.gov>
Date: Fri, 15 Jun 2007 09:06:21 -0500
another option...
if you are interested in pc104 and isa, then please have a look at the epics brick (ebrick). send any questions you might have.
http://www.aps.anl.gov/aod/bcda/synApps/ebrick/ebrick.html
tschuess,
/david
Eric Norum wrote:
May I also suggest that you have a look at the ColdFire uCDIMM cards that we are using here at the APS and Till Straumann is using at SLAC. These are full-capable EPICS IOCs and are well supported by both RTEMS and uClinux.
64 MHz Motorola ColdFire MCF5282
4 MB of on-board flash (in addition to the 0.5 MB on the MCF5282)
16 MB of DRAM
10/100 BaseT Ethernet
Three serial ports
I2C, CAN, QSPI
A24, D16 bus(with 2 chip-selects)
Here are a couple of references:
http://www.aps.anl.gov/epics/base/RTEMS/FPGA_IOC.pdf
http://www-ssrl.slac.stanford.edu/lcls/epics/talks/thurpm/norumembeddedepics.ppt
On Jun 14, 2007, at 9:48 AM, Bernhard Kuner wrote:
Dear Mister du Toit
The bad news is that most of this hardware is custom made... and is
fairly old. This includes just about everything from powersupply
controllers to vacuum controllers to beam monitors ect ect.
The one advantage is that most of this runs in crates on a bus we call
SABUS (once again custom made) in basic form it is a parallel
communication bus with data and address lines and some control signals.
This is also a system that connects several of these crates together.
Then you have a differential system that has an 8-bit data bus and about
4 control signals.
This bus seems to be something like the ISA bus. I made here at BESSY somthing similar 13 years ago, a little 8-bit addr, 8bit data + some control bus and adapted this easily to an ISA bus. So an idea could be to use PC104 with ISA bus, create a adapter to your bus and than there is just the work to create an driver for the bus access and device support to the records. This PC104 boards are shurely more cheap as a self developed one, and there is not much work on the software side, I think.
best regards
Bernhard Kuner
--Eric Norum <norume@aps.anl.gov> Advanced Photon Source Argonne National Laboratory (630) 252-4793
David M. Kline                   dkline@aps.anl.gov
Beamline Controls and Data Acquisition (BCDA)
Argonne National Laboratory, Advanced Photon Source
Argonne IL, 60439                      630.252.8639
                  Beamlines R Us
IOC options Heinrich du Toit
Re: IOC options Heinrich du Toit
Re: IOC options Bernhard Kuner
Re: IOC options Eric Norum
Prev: Re: IOC options Eric Norum
Next: VXI11 ASYN problem on VxWorks Matthew Pearson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013
Next: Sr Technical Offer for CODAC - ITER Opening Adams, Paul F.
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
