This bus seems to be something like the ISA bus. I made here at BESSY somthing similar 13 years ago, a little 8-bit addr, 8bit data + some control bus and adapted this easily to an ISA bus. So an idea could be to use PC104 with ISA bus, create a adapter to your bus and than there is just the work to create an driver for the bus access and device support to the records. This PC104 boards are shurely more cheap as a self developed one, and there is not much work on the software side, I think.The bad news is that most of this hardware is custom made... and is fairly old. This includes just about everything from powersupply controllers to vacuum controllers to beam monitors ect ect. The one advantage is that most of this runs in crates on a bus we call SABUS (once again custom made) in basic form it is a parallel communication bus with data and address lines and some control signals. This is also a system that connects several of these crates together. Then you have a differential system that has an 8-bit data bus and about 4 control signals. best regards Bernhard Kuner
| ANJ, 10 Nov 2011 |
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
