g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013
Subject: VxWorks Buffer Problems
To: tech-talk@aps.anl.gov
Date: Tue, 12 Jun 2007 15:44:33 -1000
Hi All -
Lately we have several CA crashes which may be buffer problems on our IOC's. We're using EPICS R3.13.4 on MVME-167 and MVME-2700 targets.
When I run 'netStackSysPoolShow' I see 2048 mbufs. This looks good to me. Are there other useful checks from the shell I can run to assert my image is built in the best manner possible?
The INVALID FILE DESCRIPTOR message below seems strange to me. Has anyone seen that before?
Thanks for any help,
-Matt Rippa
> CA.Client.Diagnostic...........................................
> Message: "Network connection lost"
> Severity: "Warning" Context: "10.2.2.104:5064"
> Source File: ../iocinf.c Line Number: 1488
> CAC: unexpected select fail: 851971=S_iosLib_INVALID_FILE_DESCRIPTOR
> dbCa:exceptionCallback stat Network connection lost channel unknown
> 0x93f7f4 (CA_event): CAS: TCP send to "10.2.2.151:59106" failed because "S_errno_ENOBUFS"
>0x820dec (CA_event): CAS: TCP send to "10.2.2.63:55102" failed because "S_errno_ENOBUFS"
>0x7d47e8 (CA_event): CAS: TCP send to "10.1.10.18:37796" failed because "S_errno_ENOBUFS"
>0x8408b4 (CA_event): CAS: TCP send to "10.1.5.50:56530" failed because "S_errno_ENOBUFS"
>0x845558 (CA_event): CAS: TCP send to "10.2.2.55:46467" failed because "S_errno_ENOBUFS"
>0x81b4ac (CA_event): CAS: TCP send to "10.2.2.31:41488" failed because "S_errno_ENOBUFSCAC: erro"
>r = "S_errno_ENOBU0xFS" sending UDP ms819f0cg to 10.2.2.255 (:5064
>CA_event): CAS: TCP send to "10.2.2.31:41489" failed because "S_errno_ENOBUFS"
>0x8abe64 (CA_event): CAS: TCP send to "10.2.5.43:44426" failed because "S_errno_ENOBUFS"
RE: VxWorks Buffer Problems Jeff Hill
Prev: Re: Basic Question regarding input links Luedeke Andreas
Next: IOC options Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013
Prev: Re: Basic Question regarding input links Benjamin Franksen
Next: RE: VxWorks Buffer Problems Jeff Hill
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
