I am trying to create device support for doing data acquisition that is synchronous with the AC line. I happen to have an IP-OCTAL-232 which has some general purpose inputs which can be used to generate interrupts so I am using a pulser synchronized to the AC to trigger the IP-OCTAL. I have installed the IP-OCTAL on an MVME-162 running VxWorks 5.4 and EPICS 3-13-10. Everything appears to work in that the interrupt handler gets called (right now the interrupt handler simply clears the interrupt source and increments a counter). However if I then type "reboot" at the VxWorks console it hangs. If I first disconnect the interrupt source (pulser) before typing "reboot" then it does not hang. Any ideas on what would prevent reboot from occurring? Regards and thanks, John Dobbins Lab for Elementary Particle Physics Cornell University I am not currently using drvIpac though I copied from drvIpMv162.c : This code sets up the interrupt: int acClkSetup( ) { int slot; /* Initialise the IPIC chip */
for (slot = 0; slot < IPIC_SLOTS; slot++) {
ipic->intCtrl[slot][0] = IPIC_INT_ICLR;
ipic->intCtrl[slot][1] = IPIC_INT_ICLR;
ipic->genCtrl[slot] = IPIC_GEN_WIDTH_8;
} /* using ipac interrupt request line 0 */
ipic->intCtrl[IP_OCTAL_IPIC_SLOT][0] = (AC_CLK_ILVL & IPIC_INT_LEVEL)
| (ipic->intCtrl[IP_OCTAL_IPIC_SLOT][0] & ~IPIC_INT_LEVEL);/* setup memory space for the ipac, interrupt vector goes into memory space on MVME-162 */ ipic->memBase[IP_OCTAL_IPIC_SLOT] = 0x8000; ipic->memSize[IP_OCTAL_IPIC_SLOT] = 0; ipic->genCtrl[IP_OCTAL_IPIC_SLOT] |= IPIC_GEN_MEN; /* install the interrupt handler */
if (intConnect(INUM_TO_IVEC(AC_CLK_IVEC), acClkMain, 0) == ERROR) {
perror(" Unable to install AC clock interrupt handler\n");
return -1;
}/* setup SCC2698 interrupt mask register */ *((char *)IP_OCTAL_IMRA_REG) = (char)IP_OCTAL_IMRA_VALUE; /* ivec goes to first byte of ipac mem space */ *((char *)0x80000000) = (char) AC_CLK_IVEC; /* setup Aux. Control Register */ *((char *)IP_OCTAL_ACRA_REG) = (char)IP_OCTAL_ACRA_VALUE; /* enable interrupts on ipic */ ipic->intCtrl[IP_OCTAL_IPIC_SLOT][0] |= IPIC_INT_ICLR; ipic->intCtrl[IP_OCTAL_IPIC_SLOT][0] |= IPIC_INT_IEN; sysIntEnable(AC_CLK_ILVL); printf(" Setup AC Clk Interrupt\n"); return 0; } the interrupt handler
/* clear interrupt */ temp = *((char *)IP_OCTAL_ACRA_REG); cnt++; return; }
| ANJ, 10 Nov 2011 |
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
