Kay-Uwe Kasemir wrote:
On Mar 19, 2007, at 17:12 , David Dudley wrote:
Is there a way to:
1. Set a particular database block to scan at a specific time?
Hi Dave:
There is no simple building block like a "run-at" record.
I had a similar question some time ago,
and when you search tech-talk, you might still find the answers.
Things one can do:
1) run a 'cron' job on the host that basically performs a 'caput'
to some PV which then triggers stuff.
Trivial to set up, but then you depend on the host to trigger
the IOC.
you can also run a cron job (spawn a process) on the IOC
(we do that on some of ours).
Aloha,
Maren
- Re: Timed Execution Pete Jemian
- Timed Execution David Dudley
- Re: Timed Execution Kay-Uwe Kasemir
Re: Timed Execution Andrew Johnson
<2007>
<2007>
