g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013
Subject: Re: Compiling edm
To: David Dudley <DavidDu@cctexas.com>
Cc: tech-talk@aps.anl.gov
Date: Fri, 16 Mar 2007 13:15:15 -0400
On Mar 16, 2007, at 12:48 , David Dudley wrote:
OK, have the problems with compiling the Channel Archiver looking like they're resolved.
Now, to move on to other things- edm
I'm trying to setup everything so that the binaries reside in /usr/ local/EPICS/bin/linux-x86.
Usually, EPICS 'base' and 'extensions' have their own subtree and don't end up in the same bin,lib,include,doc,...
The includes install in /usr/local/EPICS/extension/include/edm. Shouldn't they have gone into /usr/local/EPICS/include?
Exactly the thing: extensions/include (and usually also a base/include).
When you try to start the program, you get:
home/daviddu/local/src/EPICS/extensions/src/edm/baselib/O.linux-x86/ libEdmBase.so: cannot open shared object file: No such file or directory
Where'd that come from? libEdmBase.so and libEdmBase.a are in /usr/ local/EPICS/lib/linux-x86.
You tell EDM where to load those via and env. variable EDMOBJECTS that points to a file which lists the objects and shared libs where they reside.
edm/setup/setup.sh is meant to help to create those files
and set the env. vars, but I think most sites end up
doing something else manually to pick which objects they
want to use.
-Kay
Compiling edm David Dudley
Prev: Re: Compiling edm Matthieu Bec
Next: Re: Compiling edm John Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
