g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013
Subject: MEDM behavior, can't type in text edit box.
To: tech-talk@aps.anl.gov
Date: Fri, 26 Jan 2007 17:34:10 -0800
Has any seen this behavior before (or have a suggestion as to what is going on).
MEDM is installed as per the Windows Win32 EPICS Extension package along with Hummingbird Exceed 10.
On several of the Control Room consoles, MEDM behaves normally, as it does on my development desktop.
On another bunch of the Control Room consoles, MEDM launches fine but will not take keyboard input. One is able to
mouse onto a new canvas and create a new object widget, a Textt Monitor for example. When one clicks on the "Text"
field (or the "Channel A", "Channel B", "Width", "Height" fields) in the Resource Palette, one is not able to make any entries
with the keyboard.
I am certain I am using the correct keyboard plugged into the correct PCs and that the keyboards function normally in other applications.
Any suggestions?
-- Michael Urashka | Advanced Light Source
Re: MEDM behavior, can't type in text edit box. Emmanuel Mayssat
RE: MEDM behavior, can't type in text edit box. Mark Rivers
Prev: Re: EPICS Base R3.14.9-RC1 Released Benjamin Franksen
Next: Re: MEDM behavior, can't type in text edit box. Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
