g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013
Subject: ant problem when building Irmis
To: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Fri, 03 Nov 2006 10:37:40 +0100
Although being an Epics beginner, I would like to perform an evaluation of the Irmis package.
When I run "ant deploy" on the db directory, I get the following errors during the Java compilation :
compile:
[javac] Compiling 87 source files to /home/epics1/Irmis/irmisBase/db/build/classes
[javac] /home/epics1/Irmis/irmisBase/db/src/db/java/gov/anl/aps/irmis/persistence/DAOContext.java:18: error: ne peut repérer
le package par défaut « javax.crypto ». Vérifier la variable d'environnement CLASSPATH et l'accès aux archives.
[javac] /home/epics1/Irmis/irmisBase/db/src/db/java/gov/anl/aps/irmis/persistence/DAOContext.java:12: error: Class or interfa
ce `javax.xml.parsers.ParserConfigurationException' not found in import.
[javac] import javax.xml.parsers.ParserConfigurationException;
[javac] ^
[javac] /home/epics1/Irmis/irmisBase/db/src/db/java/gov/anl/aps/irmis/persistence/DAOContext.java:61: error: Type `SecretKeyS
pec' not found in the declaration of the local variable `skeySpec'.
[javac] SecretKeySpec skeySpec = new SecretKeySpec(key.getBytes(), "Blowfish");
[javac] ^
[javac] /home/epics1/Irmis/irmisBase/db/src/db/java/gov/anl/aps/irmis/persistence/DAOContext.java:62: error: Type `Cipher' no
t found in the declaration of the local variable `cipher'.
[javac] Cipher cipher = Cipher.getInstance("Blowfish");
[javac] ^
[javac] /home/epics1/Irmis/irmisBase/db/src/db/java/gov/anl/aps/irmis/persistence/DAOContext.java:64: error: Type `CipherInpu
tStream' not found in the declaration of the local variable `cis'.
[javac] CipherInputStream cis = new CipherInputStream(fileInputStream, cipher);
[javac] ^
[javac] /home/epics1/Irmis/irmisBase/db/src/db/java/gov/anl/aps/irmis/persistence/DAOContext.java:71: error: Type `DocumentBu
ilderFactory' not found in the declaration of the local variable `docBuilderFactory'.
[javac] DocumentBuilderFactory docBuilderFactory = DocumentBuilderFactory.newInstance();
[javac] ^
[javac] /home/epics1/Irmis/irmisBase/db/src/db/java/gov/anl/aps/irmis/persistence/DAOContext.java:72: error: Type `DocumentBu
ilder' not found in the declaration of the local variable `docBuilder'.
[javac] DocumentBuilder docBuilder = docBuilderFactory.newDocumentBuilder();
[javac] ^
[javac] /home/epics1/Irmis/irmisBase/db/src/db/java/gov/anl/aps/irmis/persistence/DAOContext.java:91: error: Type `ParserConf
igurationException' not found in the declaration of the local variable `pce'.
[javac] } catch (ParserConfigurationException pce) {
[javac] ^
[javac] /home/epics1/Irmis/irmisBase/db/src/db/java/gov/anl/aps/irmis/persistence/DAOContext.java:103: error: Type `NoSuchPad
dingException' not found in the declaration of the local variable `nspe'.
[javac] } catch (NoSuchPaddingException nspe) {
[javac] ^
[javac] 9 errors
(The first error message -in french- says that the "javax.crypto" package can't be found and that I have to check the CLASSPATH environment variable).
As it is the first time I am using ant, I suspect I am missing something but I don't see what : I checked that JAVA_HOME, ANT_HOME and PATH are correctly set ; then, I verified that if doing a standard Java compilation (not using ant), it compiles correctly and for example finds the missing "javax.crypto" package. I came along the ant web site but don't see there any way to solve the problem ; finally, I tried to understand the build.xml configuration file without finding any clue.
By the way, when using ant, is the CLASSPATH environment variable used, or is the classpath /only/ built from the configuration build.xml file ?
Thanks in advance for any help
Eric Lécorché
begin:vcard
fn;quoted-printable:Eric L=C3=A9corch=C3=A9
n;quoted-printable:L=C3=A9corch=C3=A9;Eric
org:Ganil;Groupe Informatique Machine
adr:;;BP 55027;Caen;;14076;France
email;internet:lecorche@ganil.fr
title:DBA / resp. GMAO / CC Ganil
tel;work:02 31 45 47 35
tel;fax:02 31 45 47 28
url:http://www.ganil.fr
version:2.1
end:vcard
ant problem when building Irmis (cont'd) Lecorche Eric
Re: ant problem when building Irmis Claude Saunders
Prev: Re: Multihomed IOC Maren Purves
Next: ant problem when building Irmis (cont'd) Lecorche Eric
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013
Prev: RE: Multihomed IOC Jeff Hill
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
