Hi All,
I've just compiled EPICS base 3.14.8.2 on Windows XP.
That worked fine.
I've used this batch file to set up my build environment:
set EPICS_HOST_ARCH=WIN32-x86
set HOST_ARCH=WIN32
rem ## Add EPICS to the path
set path=C:\cygwin\home\Andy\epics\base-3.14.8.2\bin\WIN32-x86;%path%
rem ## Add Cygnus GNU win32 to the path
set path=C:\cygwin\bin;C:\cygwin\usr\local\bin;%path%
set MAKE_MODE=unix
call "C:\Program Files\Microsoft Visual Studio 8\VC\bin\vcvars32.bat"
call "C:\Program Files\Microsoft Platform SDK for Windows Server 2003 R2\SetEnv.cmd"
These settings worked fine to compile base from a DOS commmand line
(i.e. I'm not using the cygwin bash shell).
I then did:
cd "C:\cygwin\home\Andy\ex"
perl c:\cygwin\home\Andy\epics\base-3.14.8.2\bin\win32-x86\makeBaseApp.pl -t example myexample
perl c:\cygwin\home\Andy\epics\base-3.14.8.2\bin\win32-x86\makeBaseApp.pl -i -t example myexample
make
and got:
make -C configure install
make[1]: Entering directory `/home/Andy/ex/configure'
perl c:/cygwin/home/Andy/epics/base-3.14.8.2/configure/tools/convertRelease.pl -h WIN32-x86 checkRelease
perl c:/cygwin/home/Andy/epics/base-3.14.8.2/configure/tools/makeMakefile.pl O.WIN32-x86 ../..
perl c:/cygwin/home/Andy/epics/base-3.14.8.2/configure/tools/mkdir.pl O.Common
make -C O.WIN32-x86 -f ../Makefile TOP=../.. T_A=WIN32-x86 install
make[2]: Entering directory `/home/Andy/ex/configure/O.WIN32-x86'
perl c:/cygwin/home/Andy/epics/base-3.14.8.2/configure/tools/convertRelease.pl -h WIN32-x86 CONFIG_APP_INCLUDE
perl c:/cygwin/home/Andy/epics/base-3.14.8.2/configure/tools/convertRelease.pl -h WIN32-x86 RULES_INCLUDE
make[2]: Leaving directory `/home/Andy/ex/configure/O.WIN32-x86'
make[1]: Leaving directory `/home/Andy/ex/configure'
make -C myexampleApp install
make[1]: Entering directory `/home/Andy/ex/myexampleApp'
make -C src install
make[2]: Entering directory `/home/Andy/ex/myexampleApp/src'
perl c:/cygwin/home/Andy/epics/base-3.14.8.2/configure/tools/makeMakefile.pl O.WIN32-x86 ../../..
make -C O.WIN32-x86 -f ../Makefile TOP=../../.. T_A=WIN32-x86 install
make[3]: Entering directory `/home/Andy/ex/myexampleApp/src/O.WIN32-x86'
make[3]: Leaving directory `/home/Andy/ex/myexampleApp/src/O.WIN32-x86'
MakefileInclude:74: *** multiple target patterns. Stop.
make[2]: *** [install.WIN32-x86] Error 2
make[2]: Leaving directory `/home/Andy/ex/myexampleApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/home/Andy/ex/myexampleApp'
make: *** [myexampleApp.install] Error 2
and lines 63-75 of "MakefileInclude" are:
ifeq ($(filter myexample,$(TESTPROD) $(PROD)),myexample)
ifeq (,$(strip $(myexample_OBJS) $(PRODUCT_OBJS)))
myexample_OBJS+=myexample$(OBJ)
endif
myexample_RESS+=$(addsuffix $(RES),$(basename $(myexample_RCS)))
myexample_OBJSNAME+=$(addsuffix $(OBJ),$(basename $(myexample_OBJS)))
myexample_DEPLIBS=$(foreach lib, $(myexample_LDLIBS),\
$(firstword $(wildcard $(addsuffix /$(LIB_PREFIX)$(lib).*,\
$($(lib)_DIR) $(SHRLIB_SEARCH_DIRS)))\
$(addsuffix /$(LIB_PREFIX)$(lib)$(LIB_SUFFIX),\
$(firstword $($(lib)_DIR) $(SHRLIB_SEARCH_DIRS))/)))
myexample$(EXE): $(myexample_OBJSNAME) $(myexample_RESS) $(myexample_DEPLIBS)
endif
I'm obviously doing something wrong since no one else is having this
problem! Any help appreciated.
Many thanks!
Andy
Observatory Sciences Limited Email: ajf@observatorysciences.co.uk
William James House Tel: 44 - (0)1223 - 508259
Cowley Road Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK http://www.observatorysciences.co.uk
- RE: Make error after "makeBaseApp.pl" on win32-x86 Zhan Zhang
Segment fault for edm 1-11-0m Jianguo DING
Re: Segment fault for edm 1-11-0m Ernest L. Williams Jr.
<2006>
Re: epics driver for SRS RGA100 Mohan Ramanathan
<2006>
