g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013
Subject: Digitizer needed for LCLS
To: tech-talk@aps.anl.gov
Cc: Elden Ables <ables1@llnl.gov>
Date: Mon, 1 May 2006 12:55:58 -0700
EPICS colleagues:
The LLNL group that is supplying the diagnostics to commission the LCLS needs a digitizer for an energy measurement instrument (calorimeter) with the following characteristics:
 - 100 channels sampled simultaneously
 - each channel takes 100 samples at 10us per sample (1 ms total time)
 - differential inputs
 - 12 bits minimum; 14 or even 16 bits preferred
 - sampling repeats at 120 Hz major cycle with trigger
A VME or VXI format is ideal.
Any suggestions are most welcome. Ideally, we can discuss this in depth at the June meeting.
______________________________________________________________
Stephen A. Lewis                        |
Linac Coherent Light Source             | SALewis@llnl.gov
Lawrence Livermore National Laboratory  | Tel: 925.423.4751
7000 East Ave, L-210                    | FAX: 925.423.1488
Livermore, CA 94550                     | http://www.llnl.gov
Re: Digitizer needed for LCLS Till Straumann
Re: Digitizer needed for LCLS Peter Milne
Prev: Who can help with dbLoadRecords()? Liyu, Andrei
Next: RE: Digitizer needed for LCLS Liyu, Andrei
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013
Prev: Re: Who can help with dbLoadRecords()? Benjamin Franksen
Next: Re: Digitizer needed for LCLS Till Straumann
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
