g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013
Subject: genSub tutorial needed
To: tech-talk@aps.anl.gov
Date: Fri, 17 Feb 2006 16:55:31 -0600
Can someone please give me a step-by-step explanation of how to use
the genSub records? I've read the record reference manual entry for them and
I still don't get it.
Here's what I want to do: 1. Have a function which would create two arrays, I and Q, of N points each, using several input parameters (values of other PVs) whenever any of the other PVs is set.
2. Copy these 2 arrays out to two separate VME memory address locations
(I'm copying an array to an array of addresses, not each-element-in-the-array-to-the-same-address as in a FIFO).
3. Process other records as with an FLNK link.
This sounds simple enough, but it is beyond my meager EPICS knowledge.
Thanks!
Dennis
Re: genSub tutorial needed Tim Mooney
Prev: RE: segmentation fault in ca_task_initialize running in Linux Jeff Hill
Next: RE: segmentation fault in ca_task_initialize running in Linux Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013
Prev: CA Port numbers now official Kay-Uwe Kasemir
Next: Re: genSub tutorial needed Tim Mooney
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
