g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013
Subject: RE: ASYN support for PC parallel port (Linux)
To: "Ralph Lange" <Ralph.Lange@bessy.de>, "EPICS Tech Talk" <tech-talk@aps.anl.gov>
Date: Fri, 17 Feb 2006 09:08:04 -0600
Hi Ralph,
I do have an asyn driver for the XIA Saturn DSP processor that uses the EPP port.  However, it is not a "generic" driver, it is specifc to that device.  You might be able to use the low-level part of it as the basis of a general purpose asyn driver.
You can find it at:
http://cars.uchicago.edu/software/epics/dxp
Sent: Fri 2/17/2006 7:27 AM
To: EPICS Tech Talk
Subject: Req: ASYN support for PC parallel port (Linux)
Does anyone have an ASYN based driver for generic PC parallel ports
(EPP?) as register type IO, under Linux?
Thanks!
Ralph
Prev: Req: ASYN support for PC parallel port (Linux) Ralph Lange
Next: segmentation fault in ca_task_initialize running in Linux Margaret Votava
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
