g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013
Subject: EDD on KDE
To: tech-talk@aps.anl.gov
Date: Fri, 06 May 2005 22:30:21 -0700
Now I find the following: while dm works just fine on KDE, edd doesn't,
or at least copying and pasting doesn't, but gives me a clipboard error.
The solution to this is to switch back to gnome (where I knew this
> worked before, and it still works now) just for the editing, which I did
from a different machine to save me the logging out and running
everything else back up.
(the parts of edd that do work on KDE require double mouse clicks)
Aloha,
Maren
I use KDE as a desktop, and even though my Linux box is not hosting EDD/DM, the clipboard still messes it up. I found that closing the lttle clipboard (klipper?) down in the corner of the screen fixed things up. Drove me crazy for the longest time.
Rod Nussbaumer
TRIUMF
Re: EDD on KDE Maren Purves
Prev: edd doesn't work on WBEL4 with KDE (but does with gnome) Maren Purves
Next: Re: EDD on KDE Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
