g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013
Subject: The later four ports of IP-Octal-232 could not work.
To: <tech-talk@aps.anl.gov>
Date: Mon, 28 Mar 2005 17:49:03 +0800
Hi Everyone;
   I am using the IP-Octal 232 and VIPC616 carrier board, with drvAscii/drvSerial/tyGSOctal. There are four slots(A ,B ,C ,D ) in one VIPC616 and eight ports(a ,b ,c ,d ,e ,f ,g ,h ) in each IP-Octal 232. The communication is ok between IP-Octal 232 and other devices, when the IP-Octal 232 is put into slot A, or slot B ,or slot C of VIPC616. When the IP-Octal 232  is put into slot D of the VIPC616, The later ports(e ,f ,g ,h ) of the IP-Octal 232 doesn't work again, however,the first four ports(a ,b ,c ,d ) of IP-Octal 232 work well. I have exchange several IP-Octal 232 and VIPC616 respectively, the same errors will occur again.
   Is anybody could do help me? any adivce ia appreciated! Thanks in advance.
Li,Gang
Accelerator Control Group,
Accelerator Research Center
Institute of High Energy Physics (IHEP)
P.O. Box 918-10
Beijing, 100049
P.R. China
Tel:    +86-10-88235040 ext. 808
Fax:    +86-10-88236190
E_mail: li75gang@mail.ihep.ac.cn
Prev: RE: CA Connect rates under RTEMS Feng, Shuchen
Next: RE: The later four ports of IP-Octal-232 could not work. Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013
Prev: RE: 3.14.6/asyn/vxi11 crash -- SOLVED Laznovsky, Michael
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
