Well, apparently I am no different and would like to know what your suggestions are. Here is my situation: The input signal is binary and periodic with period T=10ms. The duty cycle is ~60% ( or the TTL level high is maintained for 6ms while the TTL level low is maintained for the remaining of T) If the signal becomes aperiodic ( always TTL high or TTL low ) then there is an error ( wrong cable connection or device error ) I have an epics driver for the asynchronous device (binary input). Here are the solutions I came across: 1/ The obvious one: write a new epics driver that will query the binary input 10 times over 10 ms. If I get at least a 1 and a 0 then everything is ok => pbi->val=1 2/ I looked at soft records that could run on the top of the existing INSTIO record. That is my prefered way. I came accross the seq record in the record manual. Is it an appropriate use for it? Am I on the right direction? Do you have any other suggestions? Thanks, -- Emmanuel Mayssat Lyncean Technologies, Inc. Direct: 650/320-8300 x409 Cell: 650/793-0626
| ANJ, 02 Sep 2010 |
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
