g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013
Subject: Re: dm and edm problems with CA gateway
To: "Kenneth Evans, Jr." <evans@aps.anl.gov>
Cc: "'tech_talk'" <tech-talk@aps.anl.gov>
Date: Sat, 05 Mar 2005 14:05:03 -0500
>>> On 3/4/2005 at 18:16:49 CST, Kenneth Evans, wrote:
  > The numbers in camonitor stayed in range.
  > However, the PV did get set to DRVH or DRVL sometimes
If you have DRVH/DRVL set, you will never see a value exceeding them on a
monitor.  The value will be constrained to those limits (in convert())
before monitor() is called.
To test for these large, random values you should have DRVH=DRVL so the
limits are not used.
Brian McAllister                    Controls Programmer/Beam Physicist
mcallister@mit.edu                        MIT-Bates Linear Accelerator
(617) 253-9537                                           Middleton, MA
Re: dm and edm problems with CA gateway Kenneth Evans, Jr.
Prev: Re: dm and edm problems with CA gateway Rolf Keitel
Next: Who is using what EPICS version John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013
Prev: Re: dm and edm problems with CA gateway Kenneth Evans, Jr.
Next: RE: dm and edm problems with CA gateway Kenneth Evans, Jr.
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
