Eric Norum initiated a discussion about this around the end of 2004/11 resulting in an investigation. My conclusions are appended. I could identify two major reasons for poor results: a) epics/rtems frequently uses 'malloc_free_space' which can be a very expensive operation under RTEMS (designed to be a diagnostic). AFAIK, this has been addressed and a more efficient implementation is available with the development version (4.7). An unofficial patch is available for 4.6 but my usual workaround is to hack libCom/osi/os/RTEMS/osdPoolStatus.c:osiSufficientSpaceInPool() to always return 1. b) half/full duplex ethernet mismatch (SSRL policy is to disable autonegotiation) resulted in lost packets with tcp performance becoming really bad. After addressing these issues, I could report the following results for EPICS/RTEMS vs. vxWorks on a Synergy VGM series board (300MHz ppc): RTEMS-svgm vxworks-svgm RTEMS-svgm vxworks-svgm (1000 channels) (10000 channels) search 4.8 Mbps 3.0 Mbps 14.5 Mbps 11.1 Mbps pend 215.7 It/s 215.8 It/s 211.1 It/s 206.2 It/s async put 5.5 Mbps 6.2 Mbps 11.0 Mbps 11.5 Mbps async get 12.0 Mbps 10.6 Mbps 25.6 Mbps 19.7 Mbps sync get 0.7 Mbps 0.4 Mbps 0.2 Mbps 0.2 Mbps
wnolan wrote: Hi all, I was curious what sort or rates are being observed using the catime Original message: Here's an update/synopsis of what I know, so far: SYSTEM: RTEMS-4.6.2-svgm / EPICS 3.14.6 (server and client) NETWORK: 100-TX-full A) old (rtems-4.6.2) malloc_free_space() kills EPICS/channel access performance on fragmented-memory systems as reported previously. B) relatively poor and non-reproducable 'catime' results were due to lost packets. REASON: our networking folks like to disable autonegotiation on a full-duplex network. The driver in this case defaults to half-duplex and misses packets if the link is heavily used both ways. Enforcing full-duplex in the driver yielded much better performance (see below). SECONDARY EFFECT: In the case of lost packets, TCP response was VERY bad because 'fast retransmission' doesn't work well. Defining TCP_ACK_HACK in cpukit/libnetworking/netinet/tcp_input.c remedies that somewhat. RESULTS: A) tcpecho 'tcpecho' is a simple application that runs on the RTEMS target and echoes TCP traffic back to the sender (or, optionally discards it which is the 'unidirectional' mode below). I measured the time it took to transfer a 16MB file from a linux-x86 host. a) unidirectional, driver in half-duplex mode: ~2s (not many packets lost) b) true echo, driver in half-dup, no TCP_ACK_HACK ~347s !! (packets lost, poor retransmission) c) true echo, driver in half-dup, with TCP_ACK_HACK ~45s (packets lost, fair retransmission) d) true echo, driver in full-dup, ~2s B) catime catime to epics example app. The IOC under test ran with no calls to malloc_free_space() [rtems only] and with full-duplex enabled [both, under vxWorks and rtems]. Since the figures for the different EPICS data types are very similar, the table presents an average: RTEMS-svgm vxworks-svgm RTEMS-svgm vxworks-svgm (1000 channels) (10000 channels) search 4.8 Mbps 3.0 Mbps 14.5 Mbps 11.1 Mbps pend 215.7 It/s 215.8 It/s 211.1 It/s 206.2 It/s async put 5.5 Mbps 6.2 Mbps 11.0 Mbps 11.5 Mbps async get 12.0 Mbps 10.6 Mbps 25.6 Mbps 19.7 Mbps sync get 0.7 Mbps 0.4 Mbps 0.2 Mbps 0.2 Mbps ==> RTEMS doesn't look bad at all !! -- Till PS: vxworks suffers from the 'duplex' mismatch problem also. Here's the tcpecho code: #include <rtems.h> #include <sys/socket.h> #include <netinet/in.h> #include <string.h> #include <stdlib.h> #include <stdio.h>
if ( !bufsz ) bufsz = 10000; /* default */ if ( (sd = socket(PF_INET, SOCK_STREAM, 0)) < 0 ) { perror("socket"); goto cleanup; } if ( setsockopt(sd, SOL_SOCKET, SO_KEEPALIVE, &arg, sizeof(arg)) ) perror("setting SO_KEEPALIVE"); if ( setsockopt(sd, SOL_SOCKET, SO_REUSEADDR, &arg, sizeof(arg)) ) perror("setting SO_REUSEADDR"); memset(&addr,0,sizeof(addr)); addr.sin_family = AF_INET; addr.sin_port = htons(4445); arg = sizeof(addr); if ( bind(sd, (struct sockaddr*)&addr, arg) < 0 ) { perror("bind"); goto cleanup; } if ( listen(sd,1) ) { perror("listen"); goto cleanup; } arg = sizeof(addr); if ( (sd1=accept(sd, (struct sockaddr*)&addr, &arg)) < 0 ) { perror("accept"); goto cleanup; } if ( !(buf = malloc(bufsz)) ) { fprintf(stderr,"Unable to allocate buffer; not enough memory\n"); goto cleanup; } while ( (arg = read(sd1,buf,bufsz)) > 0 ) { i = 0; rval++; if ( discard ) continue; bufp = buf; while ( arg > 0 ) { if ( (i=write(sd1, bufp, arg)) < 0 ) { perror("write"); goto cleanup; } arg -= i; bufp += i; rval--; } } cleanup: if ( sd >= 0 ) close(sd); if ( sd1 >= 0 ) close(sd1); free(buf); return rval; }
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
