wnolan wrote:
Hi all,
I was curious what sort or rates are being observed using the catime
utility for RTEMS installations.
On a mvme2307 under RTEMS 4.6.2 running EPICS 3.14.6 I am seeing a
extream slowdown from our VX works installations and was wondering if it
was tyipical.
--- Test data
Same Hardware
MVME2307
1x OMS VME58
1x Jerger VSC16
1x ACROMAG AVME9440
and process database( about 30 records ), no state programs running.
targeting a calc input field for 10000 connections.
VX-works gives
channel connect test
Elapsed Per Item = 0.00031412 sec, 3183.5 Items per sec, 1.8 Mbps
Search tries per chan - mean=1.010000 std dev=0.099499 min=1.000000
max=2.000000
RTEMS gives
Elapsed Per Item = 0.00358250 sec, 279.1 Items per sec, 0.2 Mbps
Search tries per chan - mean=2.210500 std dev=1.631377 min=1.000000
max=8.000000
I am also seeing the slowdown on ASYN Get tests
VX works seems to run about 6 Mbps where in the same test RTEMS is
running at about 1 Mbps
A factor of 10 on channel connect and a factor of 6 on Asyn Get's
Sync gets are running at about the same rate under both systems , just
under 1 Mbps
Any help, Pointers or comparative data would be a help,
Bill Nolan
[email protected]
The RTEMS implementation of osiSufficentSpaceInPool calls malloc_free_space.
This turns out to be a very expensive operation. Take out the call to
malloc_free_space and the channel connect rate goes way up. I think that the
RTEMS maintainers have made malloc_free_space quite a bit quicker but the
change is still only in the RTEMS CVS repository.
BTW - the vxWorks implementation of osiSufficentSpaceInPool is of questionable
usefulness so it's not really clear to me that there's any point in using this
routine at all (Jeff Hill disagrees with me on this.....).
Eric Norum [email protected]
Advanced Photon Source Phone: (630) 252-4793
Argonne National Laboratory
- RE: CA Connect rates under RTEMS Jeff Hill
- Re: CA Connect rates under RTEMS (vxWorks, too) Kate Feng
- CA Connect rates under RTEMS wnolan
<2005>
<2005>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
