g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: RE: initializing a waveform record
From: "Singleton, SJ (Steve) " <Steve.Singleton@diamond.ac.uk>
To: "'Mark M. Ito'" <marki@jlab.org>
Cc: "'tech-talk@aps.anl.gov'" <tech-talk@aps.anl.gov>
Date: Mon, 5 Jul 2004 09:00:11 +0100
Hello Mark
I use EPICS subroutine (SUB) records to initialise waveform records, with
the attached code.  Because of the limitation on the number of arguments to
a SUB record it is only possible to initialise up to nine elements of the
array from one SUB record.  The arguments of the SUB record are as follows:
INPA - the waveform record
INPB - the index number of the first waveform element to be set up by this
SUB record.
INPC - the number of elements to be initialised by the SUB record, in the
range 1 - 9.
INPD to INPL - the values to which the elements are to be set.
Hope this helps.
Regards
Steve Singleton
-----Original Message-----
[mailto:owner-b-tech-talk@mail.bessy.de]On Behalf Of Mark M. Ito
Sent: 04 July 2004 02:14
To: tech-talk@aps.anl.gov
Subject: initializing a waveform record
What is there a standard way to initialize the values of a waveform record?
I saw Andrei Liyu's post from this past Apr. 8. He seems to imply that
the standard is to call dbPutField. Does one write a VxWorks subroutine
to make this call and load the array?
The array is of floats, and will be about 100 elements long. The values
are static; they never change.
I also looked at the waveform record description in the Record Reference
Manual. That did not help me given my lack of basic understanding of
this stuff.
I also skimmed the contents of the Application Developer's Guide. No
help for me there either.
Attachment: pressArray.c
Description: Binary data
Re: initializing a waveform record Gasper Pajor
Prev: initializing a waveform record Mark M. Ito
Next: Re: initializing a waveform record Gasper Pajor
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
