g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: Tornado 2.2 builds
To: "'tech-talk@aps.anl.gov'" <tech-talk@aps.anl.gov>
Date: Mon, 22 Sep 2003 13:20:40 -0500
On the epics web site there is information on building with tornado.
http://www.aps.anl.gov/epics/modules/base/tornado.php
The instructions for building with tornado 2.2 are:
"Base R3.14.1 should build on Tornado 2.2 without change (you do need to correctly set the TORNADO_VERSION_2_2 option in the configure/RELEASE file though)."
What is the correct setting for TORNADO_VERSION_2_2?
The issue I encountered is that in Tornado 2.2 (VxWorks 5.5) the c++ header files have moved.
Geoff
Re: Tornado 2.2 builds Andrew Johnson
Prev: going to ICALEPCS'03 Steve Lewis
Next: Re: Tornado 2.2 builds Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Prev: RE: going to ICALEPCS'03 Steve Lewis
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
