g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: RE: Cross compiler source and patch file for gcc-2.7.2 on Linux
To: "David H. Thompson" <thompsondh@ornl.gov>, Brian McAllister <brian@hotrats.mit.edu>
Cc: techtalk <tech-talk@aps.anl.gov>
Date: Mon, 15 Jul 2002 13:50:37 -0400
I have been building and using gcc to compile c++ on versions of vxWorks all
the way back to `92 or so, so I have been through several versions and
changes.  Most versions of gcc support vxWorks OK as long as all of the code
is compiled with the same compiler. One commercial product that I have used in
the past, RTI Control Shell, shipped a compiler with their product for many
years. At some point, at 2.6 or 2.7 the name mangling changes slowed down and
details of the binary interface became more important.   I am talking aout
things like how variables are pushed on the stack, register usage, variable
alignment in structs and classes, lots of stuff under the hood that ld would
not know about.
What we ran into with Epics 3.14 and not 3.13 was not the use of c++ in Epics
but the introduction of heavy use of c++ exceptions.   The various versions of
gcc went from one set of functions in the hidden binary interface to another
and back.  I had a slide at the San Jose Epics meeting last December that
showed how the exception API changed from version to version.  But it is more
complicated than that. Since is vxWorks a multi-thread RTOS, the exception
handler have to be re-entrant and the ones in the gnu libc.a are not.  This
matters because an exception might not always be some kind of fatal error but
in fact one way to write a program's normal execution flow. In that case,
destructors must run and each stack frame cleaned up back up to the 'catch'.
The exception handlers that are used by the the 2.7.2 WRS compiler are in the
5.4 kernel. I don't know if 5.3 included them or not. To change the compiler
you would have to change the exception handlers in the kernel. We, at SNS, did
not want to buy the kernel code or write our own version from scratch.  If you
have doubts about about this choice, just imagine writing code to implement an
undocumented API and then testing it.
In the end, the conclusion that we came to was that the best way was to pursue
the compiler source under GPL with Wind River.  That turned out to be easy
once the right contact at WRS was found.  The changes that I made were just to
port the compiler to Linux using an up to date compiler to build it.
>I built gcc-2.7.2.3 from the standard source distribution (not WRS), with
>this configuration:
>I have been using this on Redhat 7.0 to build EPICS 3.13.[1,2,4] for mv167
>and mv177 targets loading vxWorks V5.3 kernels built with the official
>Tornado 1.0 tools on Solaris.  I have had no problems.
>I tried gcc-2.8.1 first, which produced code which would load, but not
>execute.
>I have not tried this with other target architectures, and the only C++
>code built is what's in 3.13 base.
>Did you try the standard gcc-2.7.2.3 ?
>Did WRS make further changes which are needed for PPC, EPICS 3.14 or
>vxWorks 5.4 ?
Prev: epics 3.14.0Base1 build problem Peter Kurpis
Next: RE: Cross compiler source and patch file for gcc-2.7.2 on Linux dht
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Prev: Re: Cross compiler source and patch file for gcc-2.7.2 on Linux Andrew Johnson
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
