g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: epics 3.14.0Base1 build problem
To: tech-talk@aps.anl.gov
Cc: pkurpis@keck.hawaii.edu
Date: Fri, 12 Jul 2002 16:01:31 -1000 (HST)
I'm building this native-only version on solaris-sparc-gnu (Solaris 8).
The build faults on trying to build  libcas.so , because the linker
complains about multiply-defined entry points, apparently from
 caServerI.cc  and  casEventMask.cc .  The detailed message from the
build is attached below.
As for my setup...
In CONFIG_SITE, I've turned on the build of dynamic libraries, and turned
off the build of vxworks targets.
In os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu, I add the following
overrides:
	GNU_DIR = /usr/local
	LD = /usr/ccs/bin/ld -r
	DEPLIB_DIRS += /usr/local/lib
	SHRLIB_LDFLAGS_YES = -Wl,-G -Wl,-dy
These are because our gcc/g++ is built to use Solaris as/ld instead of
the GNU binutils versions.  (The last line overrides the default  -share
in shared library builds, which would introduce  -z text  to  ld  in
addition to the desired  -G  and  -dy .  The  -z text  breaks the build
of  libca.so .)
Other than those changes, it's the vanilla build system.  The problem
is shown below.  Can anybody help?
/usr/local/bin/g++ -o libcas.so.3.14 -Wl,-G -Wl,-dy      -L/usr/local/lib -R/usr
/local/lib      caServer.o caServerI.o casCoreClient.o casClient.o casDGClient.o
 casStrmClient.o casPV.o casPVI.o casChannel.o casChannelI.o casPVListChan.o cas
ClientMon.o casChanDelEv.o casAsyncIOI.o casAsyncReadIO.o casAsyncWriteIO.o casA
syncPVExistIO.o casAsyncPVAttachIO.o casEventSys.o casMonitor.o casMonEvent.o in
Buf.o outBuf.o casCtx.o casEventMask.o ioBlocked.o caServerOS.o casIntfOS.o casD
GIntfOS.o casStreamOS.o caServerIO.o casIntfIO.o casDGIntfIO.o casStreamIO.o
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::tableSize(void) const'
 is multiply-defined:
        (file caServerI.o and file casEventMask.o);
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::numEntriesInstalled(vo
id) const' is multiply-defined:
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::operator=(resTable<cas
EventMaskEntry, stringId> const &)' is multiply-defined:
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::lookup(stringId const
&) const' is multiply-defined:
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::verify(void) const' is
 multiply-defined:
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::traverseConst(void (ca
sEventMaskEntry::*)(casEventMaskEntry const *) const) const' is multiply-defined
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::hash(stringId const &)
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::splitBucket(void)' is
multiply-defined:
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::remove(stringId const
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::resTable(void)' is mul
tiply-defined:
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::~resTable(void)' is mu
ltiply-defined:
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::findDelete(tsSLList<ca
sEventMaskEntry> &, stringId const &)' is multiply-defined:
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::find(tsSLList<casEvent
MaskEntry> &, stringId const &) const' is multiply-defined:
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::traverse(void (casEven
tMaskEntry::*)(casEventMaskEntry *))' is multiply-defined:
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::show(unsigned int) con
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::resTable(resTable<casE
ld: fatal: symbol `resTable<casEventMaskEntry, stringId>::add(casEventMaskEntry
&)   ' is multiply-defined:
ld: fatal: File processing errors. No output written to libcas.so.3.14
collect2: ld returned 1 exit status
gmake[4]: *** [libcas.so.3.14] Error 1
gmake[4]: Leaving directory `/local/epics/r3.14.0Beta1/base/src/cas/build/O.sola
ris-sparc-gnu'
gmake[3]: *** [buildInstall.solaris-sparc-gnu] Error 2
gmake[3]: Leaving directory `/local/epics/r3.14.0Beta1/base/src/cas/build'
gmake[2]: *** [build.buildInstall] Error 2
gmake[2]: Leaving directory `/local/epics/r3.14.0Beta1/base/src/cas'
gmake[1]: *** [cas.buildInstall] Error 2
gmake[1]: Leaving directory `/local/epics/r3.14.0Beta1/base/src'
gmake: *** [src.buildInstall] Error 2
Prev: Re: Cross compiler source and patch file for gcc-2.7.2 on Linux Andrew Johnson
Next: RE: Cross compiler source and patch file for gcc-2.7.2 on Linux dht
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Prev: Re: iocsh under Epics r3.14 RTEMS Eric Norum
Next: drvAscii Allan Honey
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
