Brian McAllister wrote:
> >>> On 7/12/2002 at 16:40:49 CDT, Andrew Johnson wrote:
> > EPICS 3.14 needs a fairly modern C++ compiler to compile - 2.7.2 is way
> > too old. You *will* have to use a version of gcc built from the
> > official WRS sources, and Tornado 2.x when you want to upgrade to that
> > (which is exactly where Ernest Williams and David Thompson came in with
> > this problem).
> The version from WRS is still "2.7.2".
> Has WRS really hacked better C++ support into it, instead of migrating to
> the newer gcc ?
No, the WRS version is a combination of a gcc-2.7.2 C compiler back end
(modified by cygnus, probably with various bug fixes added), and later
versions of the G++ back end. In Tornado 2.0 the C++ compiler was based
on EGCS 1.0.2, in the new Tornado 2.1 and 2.2 releases I believe it's
based on the Red-Hat gcc-2.96, or maybe something newer (not sure about
the Tornado 2.2 C compiler back-end).
I think WRS pay Red Hat to produce compiler versions to their
specification. The problems Ernest and Dave wrestled with when they tried
to build a C++ cross-compiler from GNU sources were associated with name
mangling changes, and the fact that exception support is different for
each of these g++ versions.
- Andrew
Larry McVoy: "Learn how to think in C++ but don't ever program in it."
- Re: Cross compiler source and patch file for gcc-2.7.2 on Linux Brian McAllister
epics 3.14.0Base1 build problem Peter Kurpis
<2002>
RE: Cross compiler source and patch file for gcc-2.7.2 on Linux dht
<2002>
