g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: Iocsh with win32. Bad soft-record support?
To: EPICS tech-talk <tech-talk@aps.anl.gov>
Date: Wed, 30 Jan 2002 11:30:52 +0100
Hello,
I tryed to start a "soft"-IOC on PC (Windows 2000) by makeing the
example and start it as shown bellow.
Loading the database works, but not loading the records. The parse error
is not a dos/unix line ending problem! - I have tested this. Call of
iocInit shows that there is no record support for the standard records!
	C:\project\epics\base-3.14.beta1.Apps\exampleApp\Db>example
	epics> dbLoadDatabase "..\..\dbd\example.dbd"
	epics> dbLoadRecords "dbExample1.db"
	Error   Last token ")"
	input line: record(ai, "$(user):aiExample")
	   in: path "."  file dbExample1.db line 1
	db_parse returned -1
	epics> dbAllocRecord(ai) record_size =0
	filename="..\dbLexRoutines.c" line number=869
	Record support not found new record instance error
	epics> dbLoadRecords "dbExample1.db", "HORST"
	epics> filename="../../../src/libCom/macLib/macCore.c" line number=700
	<string>: user referenced but undefined
	filename="..\dbLexRoutines.c" line number=322
	macExpandString failed for file dbExample1.db
	epics> iocInit
	###  @(#)EPICS IOC CORE built on Jan 25 2002
	###  @(#)Version R3.14.0.beta.1 $R3-14-0-beta-1$ $2001/09/13 19:13:12$
	Starting iocInit
	iocInit record support for ai not found
	iocInit record support for ao not found
	iocInit record support for bi not found
	iocInit record support for bo not found
	iocInit record support for calc not found
	iocInit record support for calcout not found
	iocInit record support for compress not found
	iocInit record support for dfanout not found
	iocInit record support for event not found
	iocInit record support for fanout not found
	iocInit record support for longin not found
	iocInit record support for longout not found
	iocInit record support for mbbi not found
	iocInit record support for mbbiDirect not found
	iocInit record support for mbbo not found
	iocInit record support for mbboDirect not found
	epics> errlog = 34 messages were discarded
	iocInit: All initialization complete
	epics> exit
As I know the soft record support should be linked in the example.exe
because there is no 'ld' command for the iocsh. The link command is:
	link -nologo /WARN:3 /incremental:no /opt:ref /release
-out:example.exe
	 xxxRecord.obj devXxxSoft.obj example_registerRecordDeviceDriver.obj
exampleMain
	.obj    ../../../../base-3.14.beta1/lib/win32-x86/recIocObj.lib
../../../../base
	-3.14.beta1/lib/win32-x86/softDevIocObj.lib
	2-x86/testDevIocObj.lib
../../../../base-3.14.beta1/lib/win32-x86/iocsh.lib ../.
	./../../base-3.14.beta1/lib/win32-x86/miscIoc.lib
	b/win32-x86/rsrvIoc.lib
../../../../base-3.14.beta1/lib/win32-x86/dbtoolsIoc.lib
	 ../../../../base-3.14.beta1/lib/win32-x86/asIoc.lib
	/lib/win32-x86/dbIoc.lib
../../../../base-3.14.beta1/lib/win32-x86/registryIoc.l
	ib ../../../../base-3.14.beta1/lib/win32-x86/dbStaticIoc.lib
../../../../base-3.
	14.beta1/lib/win32-x86/ca.lib
../../../../base-3.14.beta1/lib/win32-x86/Com.lib
	LINK : warning LNK4005: Keine Objekte der Bibliothek
	/lib/win32-x86/testDevIocObj.lib verwendet
	/lib/win32-x86/miscIoc.lib verwendet
	/lib/win32-x86/rsrvIoc.lib verwendet
	/lib/win32-x86/dbtoolsIoc.lib verwendet
	/lib/win32-x86/asIoc.lib verwendet
	/lib/win32-x86/ca.lib verwendet
This seems to be right. Has anyone a idea why it doesn't work
Gruessle
    Bernhard
----------------- kuner@mail.bessy.de
Re: Iocsh with win32. Bad soft-record support? Pete R. Jemian
Prev: Re: Newbie question: symb.dbd in example application Andrew Johnson
Next: Re: Iocsh with win32. Bad soft-record support? mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Next: Re: Iocsh with win32. Bad soft-record support? Pete R. Jemian
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
