g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: RE: PowerPC woes
To: "'john sinclair '" <sinclair@mail.phy.ornl.gov>, Mark Rivers <rivers@cars.uchicago.edu>
Cc: "'Nick Rees '" <n.rees@jach.hawaii.edu>, "'tech-talk@aps.anl.gov '" <tech-talk@aps.anl.gov>
Date: Fri, 16 Nov 2001 09:31:13 -0600
Title: RE: PowerPC woes
> Nick Rees wrote:
> > While I'm on it, I was using a PowerPC mvme2402 for some of these
tests. I
> > am running Tornado 2.0.2. Whenever the PPC reboots it spends ages
doing
> > apparently nothing (i.e. about 3 minutes) just before it prints out
the
> > Attaching TCP/IP and network interface messages (i.e. very eearly in
the
> > boot).
> > Does anyone have any idea how to get rid of this. It does it twice,
so
> > waiting 5-6 minutes every boot is a bit of a bore.
I have a different suggestion from Andrew's.  I have seen a very similar problem to the on Nick describes on the MVME2700.  The problem is actually with the Ethernet 10/100 autonegotiation.  If I plug the Ethernet into a 10/100 Hub it works fine.  If I plug it into certain types of Ethernet switches (e.g. Cisco 2924 I think) it takes several minutes, and it does it twice as Nick observed. Try using a different physical device and see if it improves.
RE: PowerPC woes Nick Rees
Prev: Re: PowerPC woes john sinclair
Next: Re: PowerPC woes Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Prev: TPMC880-10 Ethernet card for PPC. Vladis Korobov
Next: RE: PowerPC woes Nick Rees
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
