g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: Questions about the Multi-channel I/O Interrupt
To: <tech-talk@aps.anl.gov>
Date: Wed, 9 May 2001 13:19:42 +0800
Hello, everyone. I have developed the acromagAVME9325 driver using I/O Intr
It's working well when one channel is used, no matter what's on other channels
 e.g.
record(ai, "$(user):aiAvme9325_Chan0")
 field(DESC, "Acromag AVME9325 Input")
 field(SCAN, "I/O Intr")
 field(DTYP, "acromagAVME")
 field(INP, "#C0 S0@")
 field(LINR, "LINEAR")
 field(EGUF, "10")
 field(EGUL, "-10")
 field(EGU, "Counts")
 field(HOPR, "10")
 field(LOPR, "-10")
 field(HIHI, "8")
 field(HIGH, "6")
 field(LOW, "4")
 field(LOLO, "2")
 field(HHSV, "MAJOR")
 field(HSV, "MINOR")
 field(LSV, "MINOR")
 field(LLSV, "MAJOR")
I tried to modify it with two channels like this:
 field(INP, "#C0 S0@")              /* channel 0 selected*/
 field(EGUF, "10")
 field(EGUL, "-10")
 field(HOPR, "10")
 field(LOPR, "-10")
 field(HIHI, "8")
 field(HIGH, "6")
 field(LOW, "4")
 field(LOLO, "2")
 field(HSV, "MINOR")
 field(LSV, "MINOR")
record(ai, "$(user):aiAvme9325_Chan1")
 field(INP, "#C0 S1@")           /* channel 1 selected*/
 field(EGUF, "10")
 field(EGUL, "-10")
 field(HOPR, "10")
 field(LOPR, "-10")
 field(HIHI, "8")
 field(HIGH, "6")
 field(LOW, "4")
 field(LOLO, "2")
 field(HSV, "MINOR")
 field(LSV, "MINOR")
This time I can't get the correct value of both channels, the two channels seems
have the same value. the ai read routine is like this:
long avme9325DI_read(register volatile unsigned short card,register volatile unsigned short chan,long *pval)
 register volatile avme9325_t **p;
 register volatile avme9325_t *pcard;
 p=AVME9325.pCardList;
 pcard=AVME9325.vmeAddrs;
 *p=pcard;
 if(!pval) return 1;
 if(chan>15) return 1;
 pcard->scanProg=0x80|(0x1F&chan); /* channel select*/
 pcard->conversionCount=0x01;      /* conversion times*/
 while(!(pcard->csr&0x80))
  } /*to determine whether the conversion finished*/
 *pval=(unsigned long)pcard->data[pcard->pData]>>4; /* read the AD value*/
 if(*pval==0xf000) return 1;
 else return 0;
I think there must be something wrong with the .db file, I have tried some ways such as add the PHAS field , or set the aiAvme9325_Chan1 to Passive scanning, but still doesn't work.
Any suggestion is appreciated. Thank you
Cheng Weixing from SSRF
RE: Questions about the Multi-channel I/O Interrupt Jeff Hill
Prev: RE: CA assert error on OSF1 version 5.1 Jeff Hill
Next: Newbie trying to move steppers in a CA client Chris Jacobsen
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Next: RE: Questions about the Multi-channel I/O Interrupt Jeff Hill
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
