g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: Re: How to configure the Capfast?
To: "Brian Bevins" <bevins@jlab.org>
Cc: <tech-talk@aps.anl.gov>
Date: Fri, 22 Dec 2000 09:02:49 +0800
Thanks.
someone of Phase3 tell me that I should get the EPICS symbols from other
EPICS members. How can I get it?
Best Regards,
shen guobao/SSRC
2000/12/22
----- Original Message -----
To: "shen guobao" <shengb@ssrc.ac.cn>
Sent: Friday, December 22, 2000 12:07 AM
| One thing you should do is to make sure that ~p3/library/epics appears
| in the symbol search path. To do this:
| Start Capfast.
| From the menubar, select Options->Search Path->Show Search Path.
| The search path will be displayed at the bottom of the window. If
| ~p3/library/epics does not appear in the search path, you can add it
| with Options->Search Path->Add Directory to Beginning.
| I hope that helps.
| --Brian Bevins
|   Accelerator Controls Group
|   Jefferson Lab
How to configure the Capfast? shen guobao
Re: How to configure the Capfast? Brian Bevins
Prev: PMC and PC-MIP configuration for PowerPC Ernest L. Williams Jr.
Next: Stored beam in SLS !!! Steve Hunt
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Prev: Re: How to configure the Capfast? Brian Bevins
Next: PMC and PC-MIP configuration for PowerPC Ernest L. Williams Jr.
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
