Is the vxWorks board support you are booting for EPICS 3.13.2 different
from the one you are booting for 3.12.2? If so, are you sure the correct
changes were made in the BSP to map the 167 memory space for DMA
operation? This is a frequent trap when using any DMA VME board like the
NI014.
Ned
> I am attempting to send commands through the EPICS GPIB interface with the
> GpibInteract program. An error is returned by the 'sysLocalToBusAdrs'
> function in drvGpib.c, and I show the output of the GpibInteract program
> below. The system was tested with a separate EPICS version (3.12.2) and
> functioned fine. I am using version 3.13.2.
> Thanks,
> Robert Willson
> willson@bnl.gov
> Output from GpibInteract, running on MVME167 with VxWorks v.5.3
> Enter Message # to Send (1 thru 5) > 1
> 0x7aefc8 (tShell): niGpibIoctl(0, 8, 0, 00000000)
> 0x7aefc8 (tShell): niGpibIoctl(0, 9, 0, 007067FC)
> 0x7aefc8 (tShell): qgpibreq(0x007067DC, 2): transaction queued
> 0x5bf200 (ib-00): niSrqIntDisable(0): ch0.csr = 0x01, gsr=0xFFFFFFFF
> 0x5bf200 (ib-00): ibLinkTask(5, 0): got an event
> 0x5bf200 (ib-00): ibLinkTask(5, 0): got Hi Pri xact, pnode= 0x007067DC
> 0x5bf200 (ib-00): GI's gpibWork() was called for command >hvon<
> 0x5bf200 (ib-00): writeIb(0071A888, 5, 0x00706809, 4, 30)
> 0x5bf200 (ib-00): writeIbCmd(0071A888, 005BF17E, 4)
> 0x5bf200 (ib-00): niGpibCmd(0, 0x005BF17E, 4): command string >q
> 0x5bf200 (ib-00): niGpibWrite(0, 0x00706809, 4, 30)
> 0x5bf200 (ib-00): writeIbCmd(0071A888, 005BF17E, 2)
> 0x5bf200 (ib-00): niGpibCmd(0, 0x005BF17E, 2): command string >q
> 0x5bf200 (ib-00): niSrqIntEnable(0): ch0.csr = 0x01, gsr=0xFFFFFFFF
> Message #1 : LinkType=5 bug=0 Link=0 Adrs=5 Type=w
> Cmd: 00: 68 76 6F 6E *hvon*
> Res: 00: 47 50 49 42 20 54 49 4D 45 4F 55 54 20 28 77 68 *GPIB
> TIMEOUT (wh* 10: 69 6C 65 20 74 61 6C 6B 69 6E 67 29
> *ile talking)*
> It looks like there is a problem in passing strings, niGpibCmd should
> print ?_%@ as its command string.
RE: Access security by IP number? Mark Rivers
Streaming video of EPICS collaboration meeting Bill DeVan
<2000>
GPIB Problems Robert Willson
Access security by IP number? Susanna Jacobson
<2000>
