g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: mbbo record
To: tech-talk@aps.anl.gov
Date: Thu, 15 Jun 2000 16:23:52 +0200 (MET DST)
I  use a mbbo record to write a value from 0 to 255 to a binary input/output
device. In this record the state value fields ZRVL through FFVL are all
defaulted to 0  and the state string fields ZRST through FFST are all
empty string. So, the SDEF field is initialized to 0.
When I want to write a value greater than 15 with dbpf, the value is written
in the record but I get the following message:
-> dbpf "testmbbo","100"
DBR_STRING:          Illegal Value
value = 0 = 0x0
-> dbgf "testmbbo"
value = 0 = 0x0
The problem is the same with unix applications like caput, caget, medm, probe...
For instance :
sigs34(1)% probe &
enum type.
textAdjustCallback : Bad value!
sigs34(2)% caget "testmbbo"
testmbbo                       Illegal Value
This is my record
-> dbtr "testmbbo"
ACKS: NO_ALARM      ACKT: YES           ASG:                BKPT: 0x00
COSV: NO_ALARM      DESC:               DISA: 0             DISP: 0
DISS: NO_ALARM      DISV: 1             DOL:CONSTANT        DTYP: ICV196
EIST:               EISV: NO_ALARM      EIVL: 0x0           ELST:
ELSV: NO_ALARM      ELVL: 0x0           EVNT: 0             FFST:
FFSV: NO_ALARM      FFVL: 0x0           FLNK:CONSTANT 0     FRST:
FRSV: NO_ALARM      FRVL: 0x0           FTST:               FTSV: NO_ALARM
FTVL: 0x0           FVST:               FVSV: NO_ALARM      FVVL: 0x0
IVOA: Continue normally                 IVOV: 0             LALM: 255
LCNT: 0             MASK: 255           MLST: 255           NAME: testmbbo
NIST:               NISV: NO_ALARM      NIVL: 0x0           NOBT: 8
NSEV: NO_ALARM      NSTA: NO_ALARM      OMSL: supervisory   ONST:
ONSV: NO_ALARM      ONVL: 0x0           ORAW: 255           ORBV: 255
OUT:VME_IO #C0 S64 @                    PACT: 0             PHAS: 0
PINI: NO            PRIO: LOW           PROC: 0             PUTF: 0
RBV: 255            RPRO: 0             RVAL: 255           SCAN: Passive
SDEF: 0             SDIS:CONSTANT       SEVR: NO_ALARM      SHFT: 0
SIML:CONSTANT       SIMM: NO            SIMS: NO_ALARM      SIOL:CONSTANT
STAT: NO_ALARM      SVST:               SVSV: NO_ALARM      SVVL: 0x0
SXST:               SXSV: NO_ALARM      SXVL: 0x0           TEST:
TESV: NO_ALARM      TEVL: 0x0           THST:               THSV: NO_ALARM
THVL: 0x0           TPRO: 0             TSE: 0              TSEL:CONSTANT
TTST:               TTSV: NO_ALARM      TTVL: 0x0           TVST:
TVSV: NO_ALARM      TVVL: 0x0           TWST:               TWSV: NO_ALARM
TWVL: 0x0           UDF: 0              UNSV: NO_ALARM      VAL: 255
ZRST:               ZRSV: NO_ALARM      ZRVL: 0x0
value = 0 = 0x0
I couldn't find this problem in tech-talk.
I use R3.13.1
Thanks in advance,
Francoise GOUGNAUD
CEA SACLAY
FRANCE
Re: mbbo record Ralph . Lange
Prev: Re: Proposed R3.13.3 Brian Bevins
Next: PID records [was Re: Proposed R3.13.3] Brian Bevins
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Prev: signoff Min Tan
Next: Re: mbbo record Ralph . Lange
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
