Liam,
You will also need to call either sysIntEnable(intLevel) or
devEnableInterruptLevel() to enable the VME interrupt level that your
board is using.
Jeff
> Are you sure you have the IACK daisy chain completed on the
> backplane? If the
> source of the interrupt isn't right next to the cpu, the chain
> can be open. Then
> the interrupts are not handled.
> Garrett Rinehart
> Intense Pulsed Neutron Source
> Argonne National Laboratory
> 9700 S. Cass Ave
> Argonne, IL 60439
> (630)252-6561
> > To: tech-talk <tech-talk@aps.anl.gov>
> > Subject: XY240 interrupts
> > MIME-Version: 1.0
> > Hello
> > I am currently trying to write some interrupt support for an XYCOM xy240
> > I/O board.
> > I have used devConnectInterrupt and intConnect to try and connect my ISR
> > with the interrupt from this board, to no avail.
> > When I input a signal to one of the interrupt inputs on the board, the
> > internal registers change properly, but my ISR does not run.
> > I suspect that either the board is not generating an interrupt,
> or that it
> > is being ignored somehow.
> > If anyone has any suggestions I would love to hear them.
> > Thanks
> > Liam O Neill
- Re: XY240 interrupts Garrett D. Rinehart
Re: pp_value in dbd file Andrew Johnson
Re: EPICS Record Reference Manual Steve Lewis
<1999>
Latest EPICS Documentation Leonard J. Reder
<1999>
