g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: Re: R3.13.1
To: sinclair@mail.phy.ornl.gov (john sinclair)
Cc: tech-talk@aps.anl.gov (EPICS Tech-Talk)
Date: Thu, 17 Dec 1998 17:11:25 +0100 (MET)
> perl -V gives:
> Summary of my perl5 (5.0 patchlevel 4 subversion 3) configuration:
Should work.
> > Is there a file called .wind somewhere under your EPICS base tree? Could it
> > be that some weird mode bits of a file called .wind cause perl's find to go
> > beserk?
> I get no result from the command: "find . -name .wind -print" executed
> in directory above base.
But where should makeBaseApp.pl get the name from if there's no file of
that name? Why ".wind"? "Wind River"? "WinDD"?
Do you use the makeBaseApp.pl matching your base version?
(With EPICS base 3.13.1 "more `which makeBaseApp.pl`" should show a CVS
version 1.15 of 1998/06/23 in line 5.)
Did the perl line in my last mail create reasonable output?
If so, I do not have any clue. Why should the same perl functions behave in
such a strange way if called from within a script?
I cannot reproduce this kind of error on my system (HP-UX). And I tried.
Any perl and sunos gurus around?
Ralph
Re: R3.13.1 john sinclair
Prev: Re: R3.13.1 john sinclair
Next: Re: R3.13.1 Steve Lewis
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
